Old 06-03-2019, 08:40 PM   #1
Pdwight's Avatar
AOS Change-out and that Blue lever
Just completed the AOS change out on my Boxster, was getting lots of blue smoke on startup...plus the original one at 81K. To say it was a pain is being nice to migraines. Take your time, clean as you go, lube O rings before reassembly...and most important when you pull that blue lever on the bottom bellows be sure, be real dang sure everything is in place and completely seated. Mine was not when the clip popped off and there we were my grandson and I removing everything all over again and starting over.....but we got it. The old AOS had a huge split in the diaphragm. After changeout, the car idles smooth...no more fluttering and high idle RPM.....fingers crossed.
Old 06-04-2019, 04:08 AM   #2
1998 Boxster Silver/Red
Yes. All of that.
1998 Porsche Boxster
Old 06-04-2019, 06:19 AM   #3
I had the same thing happen. Beer and remorse followed...
navair is offline   Reply With Quote
Old 06-04-2019, 07:30 AM   #4
Just use a worm clamp on that bottom connection.
Old 06-04-2019, 08:34 AM   #5
In fact, the last one I did myself, the previous one being done at the dealer, I found they used a worm clamp.
Dvaid
Luckyman01 is offline   Reply With Quote
