Old 04-25-2019, 02:50 PM   #1
Lightbulb ECU protection / preventive precautions
As far as I understood, problems with the ECU soaking is more a matter of time (blocked drain, dripping roof, leaky doors / simply spilling a bottle of water).
So I figured... why not wrap it in plastic and seal with silicone as a preventive treatment, so when the problem arrives, you'll have "one extra life" left while you're dealing with the water on the carpet?
P.S. My key fob not working and the alarm being silent (THANK GOD FOR THAT...) could be a sign of ECU damage somewhere in its previous life? I have no error lights on the dashboard, and the car generally runs exceptionally well.
palmhero is offline   Reply With Quote
Old 04-25-2019, 05:09 PM   #2
Or you could install a waterproof box for the ecu and call it a day. I just put mine on and was very easy to install.
$150 on Amazon.
https://www.ecudoctors.com/porsche-996-boxster-waterproof-immobilizer-case-enclosure.html
Sent from my ONEPLUS A6013 using Tapatalk
rflores2323 is offline   Reply With Quote
Tags
drain , ecu , flood , leaks , water
