04-13-2019, 07:20 PM
Sun-visor Replacement
Anybody have any idea's on replacing the plastic flip on the sunvisors?
04-13-2019, 08:25 PM
Multi-Boxer Driver
I bought a pair of visors from a Cayman. Pulled the mirror assembly out of each and did a direct swap, no wire cutting, soldering, or splicing.
Now I have functional mirror lights and no warning label on the mirror cover.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
04-13-2019, 09:15 PM
There Is No Substitute.
Do you have lighted or unlighted visors? What is the issue you are having? The flap can be repaired if that is no longer locking in the open position and the mirror section can also be replaced separate of the entire visor assembly.
04-14-2019, 07:01 AM
1998 Boxster Silver/Red
What kind of ideas are you looking for? It's a visor.
1998 Porsche Boxster
04-15-2019, 05:52 AM
the complete assembly for the mirror - not the visor - the mirror and cover are available and are easy to slide in and replace. Just like Deserion described.
"YouTube Certified in Various Specialties"
04-15-2019, 07:14 AM
Removed mine....really don't miss them except for a few times a summer.....no issues.
04-15-2019, 08:57 AM
Need For Speed
Do the Cayman sun visors you used detach and allow you to push the sun visor over to the side window area? That's one thing I don't like about the 986 sun visor, not being able to move it to the side window.
2003 Boxster S
04-15-2019, 09:37 AM
Multi-Boxer Driver
They do, but they won't work on the Boxster since the mounting point is radically different. I went with those as mounting points aside the visor is identical to the Boxster, and they were easier to find in nice condition. Cheaper, too. I think I paid about $90 for the pair I used in mine, and less than that for another set for a friend's 996. Compared to the $130+ for a new mirror it was a no-brainer.
-Chris
04-15-2019, 02:22 PM
Need For Speed
Yeah I misread your post, you only used the mirror part off the Cayman sun visor. It really is annoying Porsche made the sun visors the way they did on the 986. I would love to be able to move the sun visor to the side window at times.
2003 Boxster S
04-16-2019, 04:14 AM
Multi-Boxer Driver
I know right? Especially since it seems the 996 cabrio has it (I think).
-Chris
07-30-2019, 04:34 PM
Visor Light Flip Broken
Both of the light covers are broken.
07-30-2019, 08:40 PM
You have to buy a mirror assembly, they basically pop out but there are some wires inside so needs some soldering to be done right. Easily to take off the sun visor and work on a table. Remove 3 hex bolts but carefully.
07-30-2019, 09:18 PM
Multi-Boxer Driver
Used visors from a later 987/997 work just fine to scavenge the mirrors from. No soldering is required to remove the mirror assembly and swap it into the Boxster's visors. Once the assembly is released (two tabs along the bottom edge, use a plastic trim tool to release) the mirror can be removed and then the contact bars can be removed. Same process to install.
-Chris
07-30-2019, 09:21 PM
Any idea where I can buy them?
08-01-2019, 02:07 AM
I replaced my broken, lighted sun visor mirrors with unlighted mirrors from Auto Atlanta. Significantly cheaper, installation is literally a snap.
08-01-2019, 04:13 PM
I'm tempted to do the same thing. I have to think long and hard to remember the last time I used and needed a lighted mirror there. (I don't put makeup on while I'm driving at night)
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
08-01-2019, 08:47 PM
I ordered mine from ************************************************** ** I think, I will check the invoice I use several vendors, was about $70 I think. I-had to cut the wires in mine, and all the procedures I read said you need to desolder or cut. So I cut her wires then solder them back together put some heat shrink on the connection to finish. You need to be careful with the bolts though.
08-03-2019, 07:23 AM
We need someone to 3d print the visor light covers. Both of mine are broken. Anyone here have the skills and machine?
Sent from my ONEPLUS A6013 using Tapatalk
08-03-2019, 09:07 AM
2003 Boxster
I had the same thing, both lids hanging off. There was a video online to remove and replace the mirror/light part but it was easier just getting a pair of new complete visors from a porsche/specialist breakers. I found mine on eBay. Easy swap.
