Old 04-05-2019, 11:48 AM   #1
1998 Boxster Silver/Red
Brake fluid
I've two unopened bottles of this brake fluid. I'll be doing a flush on the 98. Am I good to go with this stuff? Thank you.
1998 Porsche Boxster
Old 04-05-2019, 02:24 PM   #2
Attachment 21863
Starter,
Yes, I had also used two bottles of the same brand on the Motive Power Bleeder and had enough of it (including the large amount of fluid required for the clutch), in accordance to the manual..
Old 04-05-2019, 03:59 PM   #3
On the slippery slope
JayG's Avatar
To do a full flush you need 1 liter
Somewhere on one of the forums I found the amounts needed for each caliper to flush the caliper and its associated line.
If you are doing just street driving, pretty much any DOT 3 or 4 fluid will work. If you are tracking or Autocross, you want a higher temp fluid like ATE type 200 or Motul 600.
2004 996 Targa Tip
Instructor - San Diego region
Old 04-05-2019, 04:33 PM   #4
Thank you! Both.
