Old 03-30-2019, 08:35 AM   #1
gabedrummin's Avatar
Clutch Pedal Going Soft
My clutch seemed to be getting soft .About a year ago when the new motor was installed I had a clutch slave and Master replaced . So I take the car in and the mechanic says I need a new master and slave .Not the same the guy that did the motor. The motor replacement took over a a month . Cost me 950.00 for parts and labor to replace clutch master and slave and bleeding with pressure bleeder ..Pick up the car on a Thursday and it dose not feel right Friday I dive to work 30 miles on the Freeway, first exit off the freeway I push the clutch and pedal goes to the floor.Car has been back 3 times and Mechanic cant seem to fix it .He says replace all the lines I say start at the slave and do one at a time work toward Master until you find the bad one . Is there one line more problematic than the others ?Whats a reasonable cost for this work? Is there anyone in Spring Texas that's a decent mechanic on German cars? 77388 . Thank you for your support You guys ROCK...!...Please no jokes about giving my car some Viagra .
