-   -   AOS or something worse? (http://986forum.com/forums/boxster-general-discussions/74816-aos-something-worse.html)
piper6909 03-19-2019 08:37 AM
Hi. My 2002 2.7 blows a little blue smoke at startup. I blows water vapor as well, but I'm pretty sure there's some blue smoke there.
Is it time to change the AOS? It has 90k miles and I don't know the maintenance history. Or could it be something more serious?
Thanks!
kk2002s 03-19-2019 11:17 AM
A little smoke at start up can be normal, especially if the cars been sitting. A very basic test for your AOS is while the car is running, remove the oil fill cap. If it's very hard to get off due to vacuum draw, then that could be an indication it's on it way out. There should be some vacuum draw but not excessive.
piper6909 03-19-2019 02:19 PM
Thank you, kk2002s.
