Old 03-11-2019, 09:48 PM   #1
Can U just pull Oil Filter,? ?
Can you just pull the filter to check for debris and not lose to much oil./?? Thanks Frank
flmont is online now   Reply With Quote
Old 03-11-2019, 09:54 PM   #2
Yes.
You'll lose what's in the canister, but not much.
Old 03-11-2019, 09:54 PM   #3
Racer Boy
Racer Boy's Avatar
Yes. I don't know off the top of my head how much oil the cartridge holds, but it isn't enough to cause the oil level to drop much.
Old 03-11-2019, 09:54 PM   #4
JBauer's Avatar
Yes not a problem.
Old 03-12-2019, 05:57 AM   #5
On the slippery slope
JayG's Avatar
In fact that is about the best way to lower the oil level a small amount should you overfill it
2004 996 Targa Tip
Instructor - San Diego region
Old 03-12-2019, 10:16 AM   #6
+ 1,
The easiest and cleanest way to get the correct level after an overfill.
Old 03-12-2019, 01:24 PM   #7
Hi, yes you can. when I pulled mine on a warm engine I lost the oil in the canister as well as a bit of a splash from the area above it.
In total a bit under half a quart oil lost.
Good luck
tzincp is offline   Reply With Quote
