Old 03-04-2019, 12:00 AM   #1
Side light not working
Hi Chaps
Wifey spotted there side lights were not working on the boxster so I removed both the headlights and changed the sidelight build for new ones.
The passenger side works but the driver side doesn't. I then swapped the bulbs over incase one of the new ones were dud but drriver side still not working.
I removed the headlight and sprayed where they connect with WD40 but still no joy
has anyone overhead this problem
MOT due so so must be fixed
YellowS2000 is offline   Reply With Quote
Old 03-04-2019, 12:24 AM   #2
Your post is confusing. Is it the side marker bulb, or a bulb in the headlight?
No matter...
Fuse A3 = right side markers.
Fuse A4 = left side markers.
Swap fuses. If no change, also check headlight connector pins.
Old 03-04-2019, 01:19 AM   #3
No matter...
Sorry yes its the buld in the headlight. In the UK we do not have side markers only the side indicator.
Its the small bulb in the headlight unit that is activated by the first turn on the headlight knob. In the UK we call that the side lights
I have sprayed WD40 on the connector pins
Peter
Old 03-04-2019, 01:40 AM   #4
No matter...
Swap fuses. If no change, also check headlight connector pins (make sure none are bent, broken, corroded, etc).
...and don't spray wd-40 on electrical connections.
Old 03-04-2019, 01:52 AM   #5
No matter...
thanks Ill check the fuses
