Old 02-20-2019, 09:55 AM   #1
What is wrong with Idling
I guess I have two questions. I went for a winter ride on Saturday before the snow came. Well it's here. I went to put my battery trickler (maintainer) and put on backwards. I was in a rush. Probably on for less than a minute. Now the trickler has a light that goes red when this happens, which it was red. So I unplugged and put back on again and the light is yellow which just means it is charging. Always does this when i don't put on for a few days. It eventually turns green. I guess my first question is what is the likely hood that i damaged anything electronic (Battery is new but not too worried if that needs to be replaced. How about the other stuff?
Now I turned the key just to see what lit (without turning over) and everything looks fine. I guess I won't know if I did any damage until I actually start. Now I can't (okay I wont) drive because there is a lot of snow outside. What is the problem with just starting and letting run until it reaches operating temperature?
Suggestions?
Thanks.
Old 02-20-2019, 12:04 PM   #2
Qckslvr's Avatar
I doubt there was any damage at all. Most chargers, and trickle charges have reverse polarity protection. If they didn't there would have been smoke, and possible fire almost immediately (seen it in our own shop a couple of times).
Qckslvr is offline   Reply With Quote
Old 02-20-2019, 02:57 PM   #3
NewUserName
Agree. That's why red light came on - it detected polarity was reversed.
You should be fine.
DoninDel is offline   Reply With Quote
Old 02-20-2019, 12:09 PM   #4
Running the car without driving it (for at least 20-30 min.) is one of the worst things you can do to the oil while the car is sitting over the winter.
Old 02-20-2019, 01:59 PM   #5
And why is that? Because the mixture is enriched at startup to actually send unburnt gas into the cats to help them warm (or hot) up to operating temperatures. So the least number of starts results in the least amount of gas sprayed onto the cylinder walls which dilutes the effectiveness of the oil on the cylinder walls which impacts the wear on the cylinder walls.
Use the maintainer. Drive it gently till warm. Then long and eventually relatively hard.
Old 02-21-2019, 01:09 PM   #6
jdiba's Avatar
Very helpful explanation Mike !
-May all the roads you travel in life be Speed Trap free.
01 986 Boxster S. Arctic Silver. 6 speed manual. IMSR/RMS.
jdiba is offline   Reply With Quote
Old 02-21-2019, 01:24 PM   #7
"50 Years of 550 Spyder"
10/10ths's Avatar
Mickfokke...
...+1
