Old 01-18-2019, 03:50 PM   #1
2000 Boxster PPI- help
Got my PPI done today on a 2000 with 88k miles on it. Sell price approx $12,000. Car is modified and has aero kit on it and lowered with coilovers. The car doesnt have a cat installed however owner said he would include muffler, cat, and header in sale. I live in Houston so kinda depends where you go for inspection to pass/fail with no cat.
Wanted to get your opinions on the compression test and fault codes. Anything to worry about?
Looks like the compression and leakdown is good. Engine seems to be in strong and great condition.
Compression test
PPI
fault codes
owner gave me 2 service records that he has below
in 2013 the car had the below serviced
Oil filter
Crankshaft seal
Flywheel bolt
IMS bearing
Engine oil
Clutch kit
Cyl head cup seal
in 2018 the below replaced
water pump
water pump gasket
Acc belt tensioner
Oil pump seal
Acc belt idler puller- lower
Coolant Pentofrost ++pink
Gasket Maker
Coolant bleed screw
Oil pressure sender
Lubro moly hugh tech 5W40 motor oil
thanks for the help
rflores2323 is offline   Reply With Quote
Old 01-18-2019, 05:51 PM   #2
Jager's Avatar
Most of the codes are due to no O2 sensors because the catalytic converters are missing. Looks like someone disconnected the Check Engine light to hide the fact that the O2 sensors are missing.
How long have you been looking for a Boxster? I would be very picky since there are many out there. Take your time.
Jäger
300K Mile Club
Old 01-18-2019, 08:16 PM   #3
This is a base car? Guess I shouldn't have sold my 2000S for $7,200 last summer...
