01-22-2019, 02:26 PM
#21
Originally Posted by Smallblock454
Check for 996 103 033 02
Mahle piston ring kit Mahle 504 40 N0
EAN 4009026929575
Contains:
Mahle 63504, Rechteckring, Nitriert, Heigth 1,2 mm
Mahle 63745, Nasenminutenring, Heigth 1,5 mm
Mahle 65959, Ölabstreifring (mehrteilig), Nitriert, Height 2,0 mm
https://catalog.mahle-aftermarket.com/eu/product.xhtml?eid=1195707#divider
Fits:
M 96.20, 85,50 Ø, 2.480 ccm
M 96.25, 85,50 Ø, 2.687 ccm
M 96.22, 85,50 Ø, 2.687 ccm
M 97.20, 85,50 Ø, 2.687 ccm
M 96.23, 85,50 Ø, 2.687 ccm
You'll find infos about correct gap in the workshop manual.
There are also piston ring sets for overbore pistons available:
Mahle 504 40 N1
Mahle 504 40 N2
Regards from Germany,
Markus
Thanks Markus,
This is helpful, seems the same ring set works for both 2.5 and 2.7 cars, as I thought. Unfortunately the Mahle sets are out of stock everywhere I looked at. Now I think I`m gonna go with this:
https://www.ebay.co.uk/itm/183341980498?ul_noapp=true
It`s an SPD product, which I`ve never heard about...
01-22-2019, 02:32 PM
#22
EAN 4009026929575
Contains:
Fits:
Mahle 504 40 N1
Mahle 504 40 N2
Markus
Workshop manual: does such thing really exist??
01-23-2019, 02:39 AM
#24
Yes, but it contains nothing about the engine internals. Porsche never intended techs in the field to work on these, so they never published anything.
01-23-2019, 12:23 PM
#25
Yes, I have the Bentley workshop guide, which is useless for engine rebuild, Wayne`s book, and a parts list with diagrams I found on the web. That`s all I have.
01-23-2019, 01:19 PM
#26
Markus, I`d go with that too if it was in the same price range, but that`s for one cylinder..
01-23-2019, 01:42 PM
#27
01-24-2019, 11:16 AM
#28
BYprodriver also had a fair point when suggested that if the wear is substantial I may have a better seal with the original rings in the same position than with new ones.
Rings can rotate during their life so there are no original ring positions. Always give a light hone before installing new or old rings to help bed them in. .
Cant find the link on running in a motor but if you are using old pistons, a few squirts on the accelerator with a back of is all that is required.
Have you ever see race cars do 10000 miles as slow speed to run them in ?
New pistons, new hone, 2 - 3 heat cycles and pedal to the floor.
Quite and old video of mine.
https://www.youtube.com/watch?v=PsEFKYULNDc
Cheers Wallace
01-24-2019, 11:40 AM
#29
Cheers Wallace
Thanks Wallace,
Yeah, I meant the same rings to go back to the same cylinders.
What do you use for honing? Just a honing tool in a drill or you take it to a machine shop?
12500 rpm is not bad for a 4T single  . What can the CB125 twin do, if the singe can be spinning like this?
01-26-2019, 02:33 AM
#30
One of these will do, https://www.toolfactory.co.nz/products/ampro-3-jaw-engine-cylinder-hone-50-175mm-75mm?variant=39640318349&gclid=EAIaIQobChMIhN7U-pyL4AIVCSQrCh33Mg57EAYYAiABEgK7IPD_BwE
Quick hone (20-40 sec) with some cutting oil is normally fine. Just roughen up to help seal the rings.
Just think of it this way, take a sharp knife and draw it across and oil stone. Home many strokes does it need to sharpen, 6 or 12. Same with and engine, the stone tears the liner microscopically, a few slides of the piston rings beds them in .
Seen some aero engines documents where they 'lap' the rings in by hand with a piston lapping jig.
Have 2 CB125 twins and one is bored to 150 cc. I need to do my magic on the motor but that will be good for 14000+ .
01-26-2019, 07:35 PM
#31
Will do. Honing will also help keep oil film on cylinder wall.
I also like to play with vintage Japanese bikes, I have a TX750 Yamaha and a CB750 K1.
