12-31-2018, 01:54 PM
P0133 Code Help!
2001 Boxster S with 99,000 miles. Earlier this year, on the way to a track day the CEL came on during stop and go traffic. Got home after track day, hooked up durametric, saw code P0133, cleared the code thinking I had a "lazy" O2 sensor when it got hot. CEL came on again later in the year, in the same conditions, engine warm, stop and go traffic, cleared code again. Went to get smog check in Dec 18 failed because pending P0133 code. So I installed all (4) new O2 sensors (Bosch), cleared the code, did two drive cycles, hooked up durametic and code P0133 shows with out the CEL lighting up. You can see the sensor cycling in Durametric. Other than O2 sensors what can cause this Code?
12-31-2018, 02:10 PM
P0133 is for the aging of the O2 sensor ahead of the three way cat on bank 1, period.
12-31-2018, 02:29 PM
P0133 Code Help
Jeff:
Thanks for your reply I understand what that code means and I replaced all the O2 sensors, cleared the code, did two drive cycles and the code returned. So I've eliminated the sensor from the equation. Any other thoughts?
12-31-2018, 03:42 PM
Originally Posted by brybart
Jeff:
The new sensor could be bad, seen that more than once...…. Try moving the sensor to the other bank and see if the code follows.
01-01-2019, 01:04 PM
If it's any consolation I having the exact same problem.
I went to smog my car and the P0133 code was present (original 02s 104,000 miles). I cleared the code and it stayed off.
I installed headers, and test pipe shortly after passing. I put all brand new 02 sensors in the car. I also put cat simulators on the down stream 02s. I drove the car for 1,000 miles with no issue, then P01333 showed up on the scanner. Cleared it, drove it for 250 miles it came back. And these were Bosch plug and play sensors. I am waiting for my replacement to show up, but if this doesn't fix it a RoW tune will be put in the car.
01-01-2019, 02:29 PM
Hi all:
I did a reset of the ECU (battery disconnect for 20 Mins), then checked for codes, no codes, then did a drive cycle, good news is P0133 is gone, bad news is P0430 has showed up. This is maddening. I filled up at the track day with unleaded race gas at the track. Could this be fuel related?
01-01-2019, 05:05 PM
Ok problem could be solved, filled up with shell pump gas, gave the Boxster a Tyrolean Tune Up, drive cycled again, no codes!
