-   -   What’s the hose that goes above intake manifold? (http://986forum.com/forums/boxster-general-discussions/74251-what%92s-hose-goes-above-intake-manifold.html)
Pigsypo 12-26-2018 04:09 PM
Can someone shed some light on the purpose of the hose? it has foam material that’s for heat insulation I assume?
Ottomotion 12-26-2018 04:43 PM
Do you have a tiptronic trans?
Quadcammer 12-26-2018 04:46 PM
without a pic, I'm assuming you are talking a hose that goes from drivers side to passenger side. This is an A/C refrigerant line. If you are referring to the hose shaped lines running front to back, those are the shifter cables.
Pigsypo 12-26-2018 06:25 PM
Yes it’s tiptronic. The hose is going from front to the back of the engine. I’ll try to upload the pic as the site won’t allow me to.
Pigsypo 12-26-2018 07:10 PM
Thank you quadcammer. Looks like the linkage cable.
Ottomotion 12-27-2018 07:49 AM
Yep....it is the linkage cable. I am guessing they located it there so as to allow one to drop the motor with trans still in car.
...Or, just drop them together like I did mine if you are so inclined.
Otto
