Old 11-09-2018, 02:32 PM   #1
1999 boxster 5 speed manual transmission issue
So, the past two days in cold weather, my 5 speed was not smooth like it has been in the past. It felt resistive mechanically, not like you would expect from cold weather, thick oil. I replaced the transmission oil and discovered metallic color in the oil and also 3 or 4 1/16 size metal pieces in the oil. It just resits a bit when cold, does better when warm, and makes a subtle, VERY subtle howling sound in 4th and 5th gear. Mostly in 4th gear. Still hear it with the new oil change. 1999 Boxster with 124k miles. 5 speed manual. I"m wondering, do I pull it and hope to fix it or pull it and replace with a used warranted tranny?
Old 11-09-2018, 03:33 PM   #2
Jager's Avatar
What transmission fluid did you use?
Jäger
300K Mile Club
Old 11-10-2018, 04:59 AM   #3
It sounds like your synchros are getting old. Good luck finding a 97-99 5 speed. Some spec boxster guys go through those like tires. You'll probably have to send yours off to get rebuilt. I recommend getting it done before you do too much damage to a gear. Not something that needs to be done right away, but sooner the better
Woody
