Tiptronic fluid change
Weather is cooling, and in a few weeks I'm embarking on my PM list of which changing the AT fluid is in order. That said...
The forum has been very helpful. I did additional reading and have a question. first... I'll first check the fill plug to be certain it will come off when I go to fill. if affirmative, I'll drain the transmission fluid. From what I've read, I'll get ~3.5 liters. Now, I'm understanding that the entire transmission holds 9 liters (including the torque converter). What I've read is that you can run the engine at idle, and in park, for not more than 3 minutes to pump the fluid from the TQ to the pan. 1. Is this correct? I would measure all the fluid that came out, then knowing how much to return to the transmission (and following refill instructions). In the alternative... what do you do? Keep filling and refilling until the fluid has been fairly well flushed out? If that's the case I'd use a compatible, but less costly fluid, to do the flush(s). My primary objective is to get out as much as possible the old fluid, and not just ~3.5 liters. I need to know if I'm buying 5 or 10 liters of fluid (assuming the 5 liter containers). Any tips, pointers, or advice is appreciated. Thank you. |
If you want to flush it with clean fluid, you would be reducing your chances of issues. |
I will be dropping the pan. New filter. New gasket. How is the fluid removed from the TC? Does everybody just leave it in there? What fluid would you recommend for the flush... as I will be concluding with the Pentosin 1 ATF. Thank you. |
Here is some good info that will explain it all. Make sure you check both out.
https://www.pelicanparts.com/techarticles/Boxster_Tech/35-TRANS-Auto_Fluid_Change/35-TRANS-Auto_Fluid_Change.htm https://www.youtube.com/watch?v=F8wSAPF582g |
The TC holds 65% more fluid than the sump. So, short of drain fill drain fill drain fill drain fill... it's really a half-assed maintenance repair. However, thank you for chiming in. |
In the end, when you are finished, you will need to verify your levels several times, topping up each time before everything settles out.
Would you have a recommendation for a temperature gun... you know... point/aim and get the temp reading? Since I'll be using that tool very infrequently I'm not looking to spend a mint. Thank you. |
https://www.princessauto.com/en/detail/infrared-thermometer/A-p8500589e |
I found tons of valuable information here. great source of information for diy'ers. keep it up guys.
what would be the recommended tiptronic transmission fluid for 2003 boxster? should it be 000-043-304-01? I found conflicting information on another forum. :) |
| All times are GMT -8. The time now is 07:40 AM. |
