Old 07-31-2018, 04:14 AM   #1
treid's Avatar
Trunk Lights
I was trying to figure out why my front trunk light was not functioning. I happened to open rear trunk and front trunk light came on !! Any ideas on this phenomena would be appreciated.
treid is offline   Reply With Quote
Old 07-31-2018, 06:09 AM   #2
1998 Boxster Silver/Red
I read upon this forum, just recently, that if one end is open, the other end, too, lights up.
1998 Porsche Boxster
Old 07-31-2018, 07:13 AM   #3
That is 100% correct... if either end open the other lights up as well.
So if they don't light up when the front only is open, the issue most likely is the micro-switch in the front latch (common BTW). Same in reverse if rear open but light does not illuminate.
Suggest you try working it w/ some good penetrating oil (Kroil, PB Blaster, etc.) to see if it'll free up first... Otherwise you'll need to remove and check the contacts, wiring etc. Repair / replace as needed from there.
Good luck
"Cool Prius!"
- Nobody
Old 07-31-2018, 09:50 AM   #4
treid's Avatar
thanks to all
Old 07-31-2018, 04:55 PM   #5
I never knew that.
"YouTube Certified in Various Specialties"
Old 10-27-2018, 02:39 PM   #6
Trunk Lights Switch
I can't find the micro switches that operate yhe trunk light, a guiding light would be appreciated (pun intended)
Boatin is offline   Reply With Quote
Old 10-27-2018, 11:28 PM   #7
Micro Switch
I think I found the rear trunk switch, hardly call it micro but I can't locate front trunk switch.
Old 10-27-2018, 11:47 PM   #8
Follow the wires (#9).
It should be attached to the latch, but may have fallen off.
Old 10-29-2018, 09:07 AM   #9
Thanks Particlewave. Appreciate the help.
