-   -   Tracking down Fault codes (http://986forum.com/forums/boxster-general-discussions/73601-tracking-down-fault-codes.html)
Aanic 10-27-2018 09:08 AM
Team,
I need some help on some fault code issues. Recently I had some serious misfires on the 99 Boxster. It was misfiring so badly that it would barely run. I replaced all the plugs and coils, and now it runs great, but I have a CEL on with the following codes:
P0102
P0112
P0154
P0302
P1318
I know several of these indicate misfires, which I believe may be holdovers, but with the two MAF codes and the Oxy sensor code I'm wondering if there is a common thread, or if they also could be holdovers.
Timeline: Within last 100 miles - new coils, filled up with gas, misfiring gone, but CEL on.
Thanks in advance,
Aaron
mgfranz 10-27-2018 09:13 AM
You did clear all codes didn't you?
Aanic 10-27-2018 10:04 AM
I tried, I'm trying to use an SCT tuner to clear the codes (my code reader was recently stolen), and its not recognizing that there are CEL codes.
JFP in PA 10-27-2018 12:48 PM
Originally Posted by Aanic (Post 581759)
Team,
P0102
P0112
P0154
P0302
P1318
Thanks in advance,
Aaron
P0102: MAF sensor, below lower limit; break in wiring, short to ground
P0112: Intake air temp below lower limit; faulty sensor, short to ground, break in wiring
P0154: O2 sensor ahead of cat on bank 2; sensor failure, wiring harness problem
P0302: Misfire on cylinder 2
P1318: No such code
Boleador 10-29-2018 12:04 PM
What's the name of the document that breaks down all the trouble codes and gives you the troubleshooting steps for each? I'd like to get my hands on it because I know I'll be in the same position as the OP sooner or later!
JFP in PA 10-29-2018 12:53 PM
You need the factory OBD II manual, now out of print, it sold for around $2K when it was released.
