-   -   Winter Garage Heat for Northerners (http://986forum.com/forums/boxster-general-discussions/73558-winter-garage-heat-northerners.html)
jaykay 10-21-2018 03:44 PM
It looks like I will have a garage (just a single) for the first time in many many years for the winter.
I hoping to get a back log of work done provided it’s not too tight in there.
How do you heat your work space with only 120V service?
The Radium King 10-21-2018 04:18 PM
propane. lots and lots of propane (garage doors are a b!tch - insulate it if you can).
rexcramer 10-21-2018 04:25 PM
I use these type of heaters in a vacation home. I put them on wall timers and cycle them on and off as needed. They are very fire safe and do not require any venting. The down side is they take awhile to heat up a room.
https://www.walmart.com/ip/Costway-1500W-Electric-Oil-Filled-Radiator-Space-Heater-7-Fin-Thermostat-Room-Radiant/898737407
356Guy 10-21-2018 04:47 PM
Assuming you don't have natural gas I would say 2 x 1500 watt heaters on different circuits should be enough if you have insulation and don't expect 20 C.
986bsdriver 10-21-2018 05:26 PM
It’s not hard to insulate. The question is how often does it open? The more it opens and loses heat the longer it will take to recovery and reheat. If it’s not opening until the cars done, I’d create a pocket of air with a piece of poly similar to what was done to windows back in the day
jaykay 10-21-2018 06:13 PM
Yeah was thinking of this but adequately venting in this space will be tricky.
jaykay 10-21-2018 06:16 PM
Was thinking of this kit for insulation until I measured things up....have a 10 foot width to address:
Owens-Corning 500824 Garage Door Insulation Kit, Includes R-8 Fiberglass Panels with White Vinyl Facing, Insulates Single Garage Door Up To 9-Feet Wide
This would allow opening as well
jaykay 10-21-2018 06:29 PM
These look like they might be pretty efficient......do you think they would be able to heat up a single car garage with an insulated door in 30min? One wall and ceiling are common to living space. What did they add to your electricity usage? I am thinking I am not going to try to work in -20 C.....maybe these will be enough.
I have used smaller units like this. There is no fan, open element, or ombustion, very neat and tidy
Porsche-Eh 10-21-2018 07:51 PM
+1 on the oil filled radiator. Whatever way you go, the 2 most inportant things you need in the garage since you are working in there are (1) carbon monoxide monitor and (2) fire extinguisher.
Also, cardboard on the cement is surprisingly warm on your back.
MWS 10-21-2018 09:42 PM
Before we built our addition and dream garage, we had small garage (apx 400sf) with no insulation (open stud cavities, no drywall)...here are a few tips:
-If you have open stud cavities, insulate them. It's cheap, easy and has big benefits.
-If you have an uninsulated garage door, use sheets of rigid foam insulation (1" or 2", whatever fits) and can be installed with a couple of dabs of construction adhesive.
-Also regarding garage door, adjust rollers (or shim if needed) so door fits tight to wall...also check door weather stripping (I found gap around door the biggest issue for heat loss).
-Heating...I never found any 120V heater that I liked...tried ceramic, oil filled radiator, etc...the only option that really worked was either propane or kerosene...but make sure you are ventilated. What I found was using kerosene heater to heat space, then shut off and open door for a few seconds...the "stuff" in garage (and cement floor) worked well as a heat-sink and even after door was opened, a small electric heater kept temps ok (or at least for a while).
-Ceiling fan...I know this sounds counterintuitive, but since heat ends up at the ceiling I found that a ceiling fan really helped keep temps more uniform. Fans are cheap (under $50), pretty simple to install (especially if you have a door opener...just run a wire from opener outlet to another well secured box, and mount fan).
-If you have a concrete floor, any thermal break will be helpful. I bought a roll of "outdoor carpet" for cheap and was amazed at how much it helped.
If you are looking for a long term solution, you should look at either a natural gas hanging unit or a 220 electric. If you are wondering what we ended up doing, our old furnace wasn't sized for our house with addition, so it went to the garage. As an added benefit, we also moved the coil and compressor giving us A/C as well as heat... :)
EDIT:
Before you buy anything, do some math. Get an estimate of the volume of the space and google the BTU's needed for reaching (and maintaining) your target temp. Also, many electric heaters don't list BTU (just watts), but again google watt to BTU. Another tip is to measure your thermal drop...on a night were temps are projected to stabilize, put a thermometer in (warm-ish) garage and check in the morning...divide degrees by hours and you'll see how much make-up heat is required per hour. Also check the amps that you have available in your garage...two heaters might sound good, but you might exceed your amp draw. Lastly, it's easier to MAINTAIN a temp than trying to REACH a temp, so always keep garage somewhat warm....as I mentioned earlier, you aren't just trying to warm the air, you'll have a huge chunk of metal (your car) acting as a heat-sink; trying to raise the temp a couple degrees is better than dozens.
Best wishes, and sorry for the length. ;)
rfuerst911sc 10-22-2018 05:40 AM
My humble opinion: you will be wasting your time with small electric heaters all that will happen is your power meter will spin like a router . You are in Canada and I'm assuming many days/nights are far below 0 degrees . So EVERYTHING in the garage is cold and you have to overcome that . Like others have said insulate , insulate and insulate . That includes walls/ceiling/garage door . Then for heat I would go with an LP or natural gas VENTED heater these are generally hung from the ceiling . They pull in outside air for combustion and obviously exhaust outside . You need a massive amount of heat for lets say 10 - 15 minutes to overcome all the cold then you can dial the heat back to maintain your comfort level . Do it once and do it right you won't regret it .
Gilles 10-22-2018 07:17 AM
+ 1 on the cardboard
When I see a neighbor taking delivery of a new large flat screen TV or washing machine, I loiter around the delivery truck since most of the times the home owner will ask the driver to please discard the 'thick cardboard box' and they get surprised when I ask them if I can keep it.. :p
In SoCal does not get too cold but there is nothing better than laying comfortably underneath your car and enjoying what you are doing.. :)
CdnRD 10-22-2018 10:58 AM
Do you have a door from the inside of your house to the garage? I will prop mine open for an hour or two before I work in the garage in the winter. It can raise the temperature a good 10C and takes the bite off. I've got a pretty good electric 240v heater but it's not nearly as fast. Keep in mind that there's probably way more moisture in your house than in your garage so you wouldn't want to do this all the time. I make sure the door is closed before I start working if I'm using chemicals. Obviously running the car is no good door open or closed. Our garage is well heated and rarely goes below freezing though.
Newsguy 10-22-2018 12:08 PM
Two words: pellet stove. I have a 30' by 40' shop with insulated walls and ceiling. The stove keeps it in the 50s even when we are around 10 degrees here in Wyoming.
Fintro11 10-22-2018 02:24 PM
;)My 986 heats my garage for me
rexcramer 10-22-2018 07:15 PM
Probably not. It will all depend on the low temp you are starting from. Set the timers to come on +/- an hour before you plan to start and see if that is enough. As others have suggested, insulation is cheap and easy to install. Our 2 heaters raise the condo's 670 SQFT 15 degrees in 30 minutes. But we are starting at +/- 50 F.
The link will help you calculate your electrical costs. https://www.saveonenergy.com/energy-consumption/
jaykay 10-24-2018 12:36 PM
.....a comprehensive body of information!
What are your collective "top in maintenance or down position" procedures during cold temps? Heat garage, move top to desired position, and then heat again to move up and closed?
Don't want to crack it
WillH 10-24-2018 04:13 PM
Get 240v and put a dragon or two on the ceiling and you can work in a T-shirt in 10 minutes from 5 or 10C. YMMV
maytag 10-24-2018 05:36 PM
Dragon?
WillH 10-24-2018 06:16 PM
Originally Posted by maytag (Post 581577)
Dragon?
https://www.stelpro.com/en-CA/dragon-ceiling-fan-heater
bbiela 10-24-2018 06:43 PM
We have 2 garages one is heated with a 220v electric heater and the other with a natural gas heater. I would only install the natural gas. The electric is loud and expensive. Good luck with the 1st world problems :)
maytag 10-24-2018 07:47 PM
I can't do natural gas, but I can do LP. The problem, though, is twofold: moisture, and combustion gasses. Neither are welcome in my shop. ;-)
rfuerst911sc 10-25-2018 02:16 AM
I believe a vented LP heater would eliminate your concerns . Where folks get into trouble is with un-vented heaters , they are cheaper to purchase but being un-vented the exhaust by product ( gasses and moisture ) goes into the space being heated .
CdnRD 10-25-2018 08:01 AM
I had an outside vented suspended gas heater in the garage of my last house. It was very quick to heat the garage up to room temperature. Even the floor and tools would warm up fast which was really nice. It was no less loud than the electric heater I have now because they both have fans. The only downside I found was that it was less efficient at keeping the temperature in the garage just above freezing which is what I like to do when I'm not working in there.
jaykay 11-04-2018 09:34 AM
First step: carpet is in !!
http://986forum.com/forums/uploads02...1541352795.jpg
MWS 11-05-2018 09:55 AM
I forgot another quick tip...to help keep the door sealed tight to weatherstripping, stand a couple 2x4s (one one each side) next to the door tracks and use some "quick clamps" to attach to track...this will stop wind from pushing the door away from seals. If you have a door opener, just remember not to open the door when blocked...or better yet, unplug it when doors are blocked.
