Old 10-19-2018, 03:31 PM   #1
Shacky
Check Engine - fuel vapor sensor code
Had my local mechanic check codes. He said it’s a voltage error fuel vapor sensor. Does that sound right and how difficult is it to replace?
I already disconnected battery and code came back.
shacky is offline   Reply With Quote
Old 10-19-2018, 03:38 PM   #2
What is the code?
Old 10-19-2018, 05:16 PM   #3
Shacky
He didn’t say
Old 10-19-2018, 10:30 PM   #4
There's no such thing as a "fuel vapor sensor" on these cars, which is why I asked.
I suppose he could mean the tank pressure sensor.
You should ask for the code. Alternatively, you can go to an auto parts store and ask them to read the code (free) or buy a cheap code reader.
Old 10-20-2018, 06:21 AM   #5
Shacky
Will do thanks! What cheap code reader would you recommend BTW?
Old 10-20-2018, 01:01 PM   #6
Shacky
P0453 evaporative emission system pressure sensor/switchhad high voltage input
Old 10-20-2018, 02:33 PM   #7
a while ago my '07 987 CS threw the same code (evap valve..?) and JFP suggested back-blowing air through the valve while applying 12V to the valve connector (to open the valve).
I disconnected the small tube that connects to the throttle body to the valve and blew air through it and the code never returned, you may want to try it.
The Evap valve its located underneath the driver side intake plenum.
Good luck!
Old 10-20-2018, 02:44 PM   #8
Shacky
BTW my Boxster is ‘99
Old 10-20-2018, 07:33 PM   #9
Shacky
Good luck!
Interesting. I’ll have to find it first. How did you apply 12V?
Saw another post on 453 and it said replace sensor on top of gas tank.
Old 10-20-2018, 07:41 PM   #10
Your code (p0453) is for the tank pressure sensor, not the purge valve that Gilles mentioned.
Old 10-21-2018, 09:20 PM   #11
Shacky
Should I try new gas cap ?
Old 06-21-2019, 10:00 PM   #12
Shacky
So it was wires to fuel pressure sensor. Mice ate through insulation. Mechanic said they make the insulation out of peanut oil!
