Old 09-15-2018, 12:21 PM   #1
gabedrummin's Avatar
Cooling fans
What triggers the cooling fan relay to kick the fans on? My left fan is not comming on and the fuse is good and so are all the relays .Checked both fuses and all 4 relays.? Thank you all ..!
Old 09-15-2018, 12:30 PM   #2
Engine temperature.
Use a jumper at the relay socket. This will tell you if it's a relay signal issue or if the problem lies in the wiring or fan itself.
Old 09-15-2018, 12:34 PM   #3
Jump between pins 30 and 87, like this:
Old 09-15-2018, 01:46 PM   #4
thom4782's Avatar
if the left high speed fan works, but the low speed one doesn't, then the most likely culprit is the ballast resistor.
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
