Old 08-26-2018, 05:37 PM   #1
More of a truck guy
Rear Spoiler Doesn’t Work - ‘97 Boxster
Spoiler doesn’t extend at speed, nor does it work with the switch. The spoiler light comes on in the dash at speed. Swapped in another spoiler mechanism, thinking it might be a bad mechanism, and no luck there. All fuses and relays have been replaced.
HOWEVER, with the manual switch (by fuse box) unplugged, and I connect the rear wiring harness to the spoiler unit, I can hear the relay clock, and it will raise the spoiler about 1/2” and stop. If I unplug and plug back in, it will go up another 1/2”. I kept doing this (duh!!!) and got a fully extended spoiler.
I figured out how to “hot wire” it to retract it, and then extend it again by swapping the (-) and (+) on the green/yellow and blue/green leads on the spoiler motor harness. All works smoothly.
I tested the switch by the fuse panel and it passed.
Also, I tried to make heads or tails of the wiring diagram. I’m more mechanical oriented than automotive electronics. I just got a headache!
Any advice on how to troubleshoot? Not really sure how the wiring is designed to make it function.
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 08-27-2018, 09:00 AM   #2
I might have the same problem, bought a spare spoiler assembly to swap it with. Following this thread to see if anyone has any ideas.
Long shot: Ignition switch? Or perhaps there’s some sensor which triggers prematurely?
square-root is offline   Reply With Quote
Old 08-28-2018, 06:05 PM   #3
More of a truck guy
I need help. I have been digesting the wiring diagram for the spoiler. I have a couple of questions:
1. Does the spoiler switch by the fuse panel, switch power or ground? It goes right to the instrumentment cluster.
2. When the Boxster comes to speed, does the instrument panel send 12v to the extend relay, or does it switch a ground, to complete the circuit? Same thing for the retract relay?
Thanks!!!
Old 01-05-2019, 01:22 PM   #4
Spoiler not working
Any updates? Have you resolved the problem?
2001 Base with 2002 3.2 DIY swap 97 "short shift" tip "Joe Toth" aerodynamics, Z top, painted headlights.
2001 Boxster 5 speed
Turbodad is offline   Reply With Quote
Old 01-05-2019, 01:47 PM   #5
More of a truck guy
Yes. I checked and tested all parts of the system, and narrowed it down to a bad instrument cluster. The cluster controls the up/down at speed. Found a cluster with about same mikes and all works great now.
Old 01-06-2019, 12:16 PM   #6
How many miles to the mike? :-)
1941 Dodge Luxury Liner Coupe
Old 01-18-2019, 04:52 PM   #7
OK just catching up on an old thread. Since I cannot see the spoiler while driving, and I usually driver alone, I don't know if it's working. Is there a way to check? What triggered me was your comment about the light on the sash. Is it supposed to come on when the spoiler is deployed? I have a '98 and the spoiler does deploy using the under dash switch.
Zibodo is offline   Reply With Quote
Old 01-18-2019, 04:58 PM   #8
More of a truck guy
Easiest way is to fet someone to follow you when you go 75 or so. You could also put a piece of tape on across the spoiler, and check it after zippy drive.
No, the light comes in if there is a malfunction with the spoiler.
