Old 08-09-2018, 10:11 PM   #1
Intake chirp and rev whine - please help diagnose these sound clips
Hi guys,
I have separate clips of two different, but annoying and maybe concerning noises that I'm clueless on.
The first is a chirp upon an initial blip of the throttle seemingly coming from the air intake. I am de-snorkeled.
The second is a whine that corresponds with the engine's revs. It's the same whether in gear or in neutral, clutch in or out. I installed a 997 shifter today and don't recall hearing the sound previously, but I could be wrong. I recently had my water pump replaced. Could it be the serpentine belt? It's not the transmission right, since it's the same whether in or out of gear?
Sorry for the crappy videos, but I didn't know how else to record the sound. Thanks in advance for any help you can offer!
ScottAZ is offline   Reply With Quote
Old 08-09-2018, 11:15 PM   #2
Boxing in Australia
Whine
My 2003 2.7 tip has whined ever since I bought it 3 years ago, it is particularly loud when cold, I have always assumed they all do that having read a road test where the tester remarked that the Boxster makes similar noises to the old air-cooled cars,
Perhaps I should be worrying my service guy has never mentioned it,
Cheers
Alan Mackew is offline   Reply With Quote
Old 08-09-2018, 11:30 PM   #3
Cheers
Cool, thanks. Does it sound similar to mine in the second video below? It seems more noticeable and whiny in the second half of the clip.
Old 08-10-2018, 03:36 AM   #4
98 Arctic silver 986
tommy583's Avatar
I would take the belt off to see if both or either of the noises go away. It could be a bad belt or one of the pulleys. The chirping noise could also be caused by a loose spark plug. Both of these suggestions are free and pretty easy to do.
Old 08-10-2018, 06:05 AM   #5
mine sounds just like yours, it's a 97 2.5
i actually thought at first there was interference from a bad ground like in an aftermarket radio that was not installed correctly but it seems that's just how they sound!
dav9515 is offline   Reply With Quote
Old 08-10-2018, 08:03 AM   #6
Thank you! I'll replace the serpentine belt today and see what happens. I assume it's safe to run the engine without the belt for a moment to see if the whine is gone? If it is, and therefore it points to one of the pulleys, what is my next course of action?
Old 08-10-2018, 11:23 AM   #7
With the engine cover off, it's less of a chirp and more of a sucking sounds. Does it sound like a leak somewhere or is that normal? Thanks!
Old 08-10-2018, 01:14 PM   #8
2003 S, Arctic Silver, M6
paulofto's Avatar
Yeah that sure sounds like air being sucked in somewhere. Vacuum leaks can be very hard to trace if that is what it is but it sounds like air actually being drawn in to the throttle body or the intake manifold. Maybe a loose clamp?
Old 08-10-2018, 01:45 PM   #9
I tightened down all the clamps I could see. They all had some room in them but I didn't want to over-tighten so I didn't go nuts. Whatever I did, didn't help. And with the engine cover back on, it's back to chirping. Ugh.
Old 08-10-2018, 03:49 PM   #10
Isn't that a crack in the intake manifold connection tube in the front of the video?
1941 Dodge Luxury Liner Coupe
Old 08-10-2018, 03:54 PM   #11
That?
I think it's some sort of stamping on the rubber. I saw it too, and did a double take. Now, I'm second guessing myself a little.
Old 08-11-2018, 12:47 PM   #12
Took the serpentine belt off and the whine is still there. I wonder if it's normal. Or could it be transmission related? I do hear a rattling in the there that sounds like I may have a loose spark plug. I'll tackle that tomorrow. Thanks again for any and all input.
Old 08-11-2018, 12:59 PM   #13
Originally Posted by ScottAZ View Post
That?
That's an arrow stamped into the crossover tube.
You can see it here:
particlewave is online now   Reply With Quote
Old 08-11-2018, 01:03 PM   #14
Great, thanks. I was trying to figure out if that’s the crack that Anker thought he saw.
Old 08-11-2018, 03:27 PM   #15
That's it! Its just an arrow.
Old 08-11-2018, 05:51 PM   #16
I changed the plugs and the chirp went away. One down...
Old 08-11-2018, 07:36 PM   #17
tommy583's Avatar
Nice
