Old 08-07-2018, 10:17 AM   #1
Originally Posted by Brian in Tucson View Post
Can't do much better than this: https://www.pelicanparts.com/More_Info/99660520301.htm?pn=996-605-203-01-OEM
OEM part number is 99660520301
Not that valve.
This one (under the left side intake manifold): https://www.ecstuning.com/b-bosch-parts/purge-valve/0280142300sj/
Search for the part number (bosch 0280142300SJ) and you can find it for less than $30.
Sometimes they can just be blown out/cleaned, so you may want to try that first.
Old 08-07-2018, 10:20 AM   #2
Not that valve.
Is that the correct part for my 2000 986 base? The part number they list there is different from the one I have come across. I also come across 0280142380.
dlewis23 is offline   Reply With Quote
Old 08-07-2018, 11:12 AM   #3
Super Moderator
Give us a call at 888-280-7799 and one of our Porsche part specialists will be happy to help you out with sourcing the correct part.
Dmitry at Pelican Parts is offline   Reply With Quote
Old 08-13-2018, 10:53 AM   #4
Not that valve.
I don't want to jinx it, but I replaced this part on my Boxster last week and I have filled up twice so far and have had no issue starting the car right after.
The part I took of the car did not seem bad but had a part number I never seen in my research so I assume it was changed at some point before.
But thanks for the part number and advice on what to change.
Old 08-28-2018, 01:56 PM   #5
Does this require removing the left intake manifold?
Luckyman01 is offline   Reply With Quote
