Old 08-07-2018, 08:52 AM   #1
First Porsche - Stuck at gas station
I just purchased my first Porsche a 2000 Boxster and it runs great but yesterday I got stuck at the gas station after filling it up. The car would not start after I filled it up, it would just crank. If I pushed the pedal while it was cracking it would start, run rough and just die a couple seconds later.
After about 15 minutes max sitting the car started and ran fine.
When I purchased the car it has a CEL with P0446. I have cleared the code and changed the gas cap before I went to the gas station yesterday so the gas cap was not an issue.
I did not get a CEL back on since the problem with starting the car yesterday.
Any idea what my next part to check/replace should be? Looking around I see others talking about the EVAP shut-off valve, EVAP Purge Valve (Which I can not find the part to order) or the Fuel Tank Bleeder Valve.
Any input is appreciated.
dlewis23 is offline   Reply With Quote
Old 08-07-2018, 09:27 AM   #2
does the tach jump while cranking? If not, could be a bad Crank position sensor
Old 08-07-2018, 09:42 AM   #3
Bad EVAP purge valve.
Old 08-07-2018, 09:43 AM   #4
Where do I find this part? I have been looking for it around and I can only find 2 used ones on ebay.
Old 08-07-2018, 10:40 AM   #5
Can't do much better than this: https://www.pelicanparts.com/More_Info/99660520301.htm?pn=996-605-203-01-OEM
OEM part number is 99660520301
2001 Boxster
2007 Toyota Highlander
Old 08-07-2018, 11:11 AM   #6
I have found that one, but there is one that is under the left side intake plenum that is a Bosch part that is also a purge valve and I can not find that part.
And is the problem im having the part you have there, or the one under the intake plenum that I can't find.
Old 08-07-2018, 11:17 AM   #7
Not that valve.
This one (under the left side intake manifold): https://www.ecstuning.com/b-bosch-parts/purge-valve/0280142300sj/
Search for the part number (bosch 0280142300SJ) and you can find it for less than $30.
Sometimes they can just be blown out/cleaned, so you may want to try that first.
Old 08-07-2018, 11:20 AM   #8
Not that valve.
Is that the correct part for my 2000 986 base? The part number they list there is different from the one I have come across. I also come across 0280142380.
Old 08-07-2018, 12:12 PM   #9
Super Moderator
Give us a call at 888-280-7799 and one of our Porsche part specialists will be happy to help you out with sourcing the correct part.
Dmitry at Pelican Parts is offline   Reply With Quote
Old 08-13-2018, 11:53 AM   #10
Not that valve.
I don't want to jinx it, but I replaced this part on my Boxster last week and I have filled up twice so far and have had no issue starting the car right after.
The part I took of the car did not seem bad but had a part number I never seen in my research so I assume it was changed at some point before.
But thanks for the part number and advice on what to change.
Old 08-28-2018, 02:56 PM   #11
Does this require removing the left intake manifold?
Luckyman01 is offline   Reply With Quote
