Old 07-23-2018, 03:03 AM   #1
Climate Control Display Panel
My Display / LED Climate Control has lost it. I can get a replacement kit for $109 AUD (about $70 US).
Interested in comments on those that have done it & the degree of difficulty
:dance:
Boatin is offline   Reply With Quote
Old 07-23-2018, 03:10 AM   #2
Stupidly simple. It takes 5 minutes once you have the CC unit out.
3 screws to remove front panel, I think about six screws to separate the circuit board from the front panel, twist the metal LCD frame tabs straight to remove it from the board, then pull it free. Swap panels, then put it back together.
No soldering required. You'll need a philips head screwdriver and a pair of pliers (standard or needle nose).
Some pictures here:
http://www.rennsportkc.com/996boxster-climate-control-display/
Old 07-23-2018, 03:32 AM   #3
Stiglitz's Avatar
I used the kit from 914rubber, it works perfectly and super easy to install.
Stiglitz is offline   Reply With Quote
Old 07-23-2018, 01:21 PM   #4
Coaster's Avatar
me too, over a year ago. No issues.
Coaster is offline   Reply With Quote
Old 07-23-2018, 04:21 PM   #5
Thanks Gents, I'll order the kit now.
Old 07-28-2018, 01:43 PM   #6
barkinfool's Avatar
Just did this & agree it is a very simple repair with the 914rubber kit -- well worth it. Thanks for the suggestion & happy to have my display back to perfect!
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
Old 08-05-2018, 09:23 PM   #7
JayG's Avatar
Go with 914 rubber
great product and cust service
