Old 07-20-2018, 09:36 AM   #1
Bleeding Clutch
Is there a secret process, I found this a PIA, hard to get too!
David
Luckyman01 is offline   Reply With Quote
Old 07-20-2018, 10:31 AM   #2
A lot of people find removing the driver's side rear wheel helps. I don't bother with that, and a stubby wrench to be able to swing it in the confined space. Really isn't much of an issue.
Old 07-20-2018, 11:18 AM   #3
Ciao's Avatar
A stubby wrench is key, a flashlight helps to find the nose bleed which is not too tight and easy to loosen. An assistant to press on the clutch is required.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 07-20-2018, 11:29 AM   #4
An adjustable hood prop eliminates the need for someone to hold the clutch pedal down.
Old 07-20-2018, 10:57 PM   #5
Ugh... I hate it when my clutches bleed... bummer. :-)
