-   -   Battery replacement (http://986forum.com/forums/boxster-general-discussions/72797-battery-replacement.html)
Nystanlycup 07-16-2018 10:34 PM
Battery replacement
Hi all,
I have a 2001 base and my battery is dead. I've jumped it a few times but I think it's a goner, (sticker says it's from 2010). My question is; what is the best battery to buy? I can't seem to find the same answer anywhere online and I'd hate to have the wrong battery shipped. Any help would be great, thanks!
Mig 07-16-2018 11:27 PM
Walmart. Not kidding. Excellent batteries. Perfect fit. I put one in my 2007 Cayman S.
I wouldn’t have considered Walmart batteries. I always like using OEM, but in this case the information I read online suggested it was the way to go.
Cunningr 07-17-2018 12:31 AM
Several good replacements, you want stock or something lighter? Lighter there is a Optima battery but you need a bracket from rennline as its a smaller size.
Deserion 07-17-2018 04:34 AM
Second the Walmart batteries. They're made by Johnson Controls (pretty much the biggest player in the country), and since Walmart is everywhere it makes replacement a cinch.
mikesz 07-17-2018 05:13 AM
I went with an Optima. I was concerned about the venting under the hood. I have a 99 Base.
husker boxster 07-17-2018 05:30 AM
I have good luck with Interstate batteries. They last a long time and stay charged when my LE sits during the winter w/o a tender. I'm in yr 6 with the battery in my LE. Just replaced the battery in my CSS.
kk2002s 07-17-2018 06:42 AM
I went with interstate. Interstate was there when I bought so I just continued
Nystanlycup 07-17-2018 06:48 AM
Thanks guys!
lcsdoug 07-17-2018 10:01 AM
+1 for Walmart
Walmart battery fit perfect. When I changed the battery I plugged my small charger into the cigarette lighter to keep all my settings. I had an empty pill container that fit over the plus lead of the battery to keep it from shorting out while I changed the battery. Worked great, didn't even have to reset my radio stations.
Ciao 07-17-2018 01:03 PM
I went with Porche Dealer battery; 6 year warranty--no prorate full replacement if it dies before 6 years.
Blackcloud 07-17-2018 02:09 PM
Generally speaking, replace the battery every 4 or 5 years.
rp17 07-17-2018 05:55 PM
+1again on walmart batteries. I just had a dead battery on my beater. Walmart was out of stock so bought one from auto place. I had to wait for autoxxxx to check and charge before they would replace it while my transport was waiting for me outside 30 mins. Walmart is no questions asked and they are open 24 7... That makes it worth it!!
Lew 07-17-2018 08:30 PM
https://wm6.walmart.com/Battery-Finder.aspx
For the Boxster's. Plenty of CCA's
morgal48 07-18-2018 01:38 PM
Which Optima? Couldn't find any for any engine, any year through 2004. Is it a special? I have 2 red tops in my GMC and would like to find one for my car. Good stuff.
tightbox 07-18-2018 01:59 PM
Did you fix your IMS problem?
BYprodriver 07-18-2018 01:59 PM
I have a bracket for a Odessy 625 thats $40.
Geof3 07-19-2018 10:33 PM
Interstate, Die Hard, pretty much any top end battery that fits the amperage etc. I’m partial to Interstate.
Cunningr 07-20-2018 01:47 AM
The diy i found at rentec by geof said he used a Optima 34R. He has some fabrication info on diy mount plate or you can by one.
Burg Boxster 07-20-2018 12:35 PM
Correct, 34R is accurate re: CCA and post orientation.
Yes, an Optima requires tie down adapter plate... either pre-fab or custom made using HDPE cutting boards from Target (middle size IIRC), BBB, etc. and a couple screws, washers, and nylon lock nuts.
NO - Optima's are not worth their price premium. Haven't been since they cut down from 84months to 24 & 36 month warranties. Still a good AGM battery but not worth $50-$100+ premium for equal / less warranty than other brands...
Good luck :)
mgfranz 07-20-2018 03:12 PM
When mine died, I went with a Bosch replacement from PepBoys, mostly because of the replacement warranty. Since I don't drive my 986 very often, it sat for a month or two before trying to restart it, battery was dead. Took it back to PepBoys they gave me a new one. Now I disconnect it when I know it will be sitting for a while...
As a side note, I use Bosch in all my cars, except the truck, OEM on all of them.
