Old 07-12-2018, 12:55 PM   #1
Goth Popper
99 Boxcutter's Avatar
Fan won't stop spinning, windows going up and down???
I finally got my trunk open, but there's something seriously wrong with my 2001 Boxster S. The fan won't stop spinning and it drained the battery, so I connected jumper cables and when I try to start the car, the lights on the dash flicker and the windows keep twitching up and down.... Maybe this video will explain it better.
https://www.youtube.com/watch?v=bir2xWvFlD4&feature=youtu.be
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
Old 07-12-2018, 01:26 PM   #2
Check the immobilizer under the drivers seat for water damage.
Old 07-12-2018, 04:11 PM   #3
Next suspect would be the ignition switch !
pomerlo is offline   Reply With Quote
Old 07-12-2018, 04:59 PM   #4
Definitely a prime suspect!
Old 07-12-2018, 05:57 PM   #5
Boxing Cat's Avatar
A weak battery can cause all kinds of strange behavior. Check the carpet under the driver seat for water
If dry, then replace the battery. If problem persists, then replace the ignition switch.
Boxing Cat is offline   Reply With Quote
Old 07-19-2018, 10:37 AM   #6
Goth Popper
I have removed the immobilizer and it looks spotless. Is there anyway to test it?
Old 07-19-2018, 11:04 AM   #7
Not really. If it looks good, move on.
Go to your local auto parts store to have your charging system tested. They should also have an ignition switch.
