Old 07-10-2018, 10:11 AM   #1
Preventive AOS replacement
I recently purchased a 2001 Base that appears to have an AOS that's been there for some time. Is it worth replacing it as a preventive measure or just wait until it fails? The car seems to run really well minus needing a motor mount. No excessive oil in the intake that I saw when I cleaned the TB, but there was definitely residue. I did not measure vacuum on the crankcase though.
dguy535 is offline   Reply With Quote
Old 07-10-2018, 10:25 AM   #2
kk2002s's Avatar
It is one of those items that when it goes you could be stuck. I bought one, cared it around with me on road trips for a year. Then finally changed it as preventive. Original never gave my any trouble. Unfortunately, it is not uncommon for a new AOS to go bad right after install. Because it was of poor quality new. I have been lucky with my new AOS so far.
Seal Grey
Old 07-10-2018, 10:35 AM   #3
I too have an '01 base that I purchased without any service history about a year ago. I drove it for 6-8 months then had IMS, RMS, clutch and AOS done all at same time. More piece of mind. Plus I've seen a handful of AOS blow during autocross events and didn't want to do that.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 07-10-2018, 11:24 AM   #4
for street driving, I would replace only when you start to see signs of failure. If you track it, might be worth swapping it out.
Old 07-10-2018, 02:09 PM   #5
MWS
I'd do it when any other engine work is being done as part of the "while I'm there, might as well" philosophy.
Old 07-11-2018, 09:04 AM   #6
BYprodriver's Avatar
This is the answer! They ain't making them like they used to. While the 986 was in production AOS were tested before installation & any that failed the test were returned to the manufacturer. I buy from the dealer when it fails so you get a 2 year warranty on the best part available.
Old 08-04-2018, 10:31 PM   #7
This is why I buy as many parts as I can from F.C.P Euro. Lifetime warranty on ALL parts.
Prelude Guy is offline   Reply With Quote
