Old 06-25-2018, 05:40 PM   #1
Porsche = 2 syllalbe word
maddogxx's Avatar
brake wear light
HI guys, my brake wear light started coming on intermittently about 3 weeks ago. I finally got around to replacing the brake pads. I started by inspecting the rears ansd saw that the pads were really low so I replaced just the rear. The drivers side was the worst with the pad worn down to the sensor on each pad, the pass side was worn thru too but not quite as far as the drivers side. I inspected the wear sensors on both side and neither sensor showed any signs of damage. So I took for a test spin and the light came back on so I figured the fronts needed to be changed. So I replace the front pads even though they had pad left but they were close to the sensor but not thru left. Went for a test drive and the light comes right back on. So I had one new sensor and put that on the drivers side rear because that was where the most wear was, took it for a drive and the the light comes right on, came back inspected the pass side sensor again but it shows no sign of damage. Is there some type of reset I have to do to get the light turned off? Thanks in advance.
maddogxx is offline   Reply With Quote
Old 06-25-2018, 05:52 PM   #2
still plays with cars...
BoxsterSteve's Avatar
If you’ve worn into the sensor, it needs to be replaced for the light to go out.
Alternately if you’re cheap like me, you could strip and twist the ends together and seal them up with shrink tubing.
Zip tie whole works to the the back side of the strut to keep it out of the way of suspension parts and the rotating tire.
You should do an annual brake & suspension inspection anyway, so the wear sensors are kind of unnecessary.
Six speed 2000 Boxster S
Old 06-25-2018, 09:59 PM   #3
Its very simple; as long as the wear sensor wire has continuity, the dash light is off. When continuity is broken, then the dash light turns on.
The little nub on the end of the brake wear sensor has a wire embedded in it and when it gets worn, then the wire is broken, electrical continuity is lost, and the dash light turns on.
Thus, there is no computer or electronics, so there is no reset. As Steve mentions above, you can simply cut the brake sensor wires and twist the ends of the wire together and the dash light should turn off. This is an easy way to check if the light bulb itself is working properly.
Otherwise, I'd check the wear sensor connector (where it plugs into the car wire harness), its could be loose or has some dirt or other contamination in it so its randomly losing continuity and causing the dash light to flicker.
