2003 Boxster S... handling/steering
I just purchased a 2003 Boxster S with 69K miles on it. I am very pleased on how the car was taken care of, but an issue has developed.
1) At low speed the steering is very heavy and even at higher speeds it continues to feel much heavier than it should. 2) The car is tracking poorly in that it seems to be overly sensitive to any changes in the road surface and will dart off in directions associated with changes in the pavement such as ruts. In addition there is a feeling that there is a lack of centering in the steering and a some wobbly feedback. I have confirmed that the car has not been in any reportable accidents and there is no evidence of any front end damage. The previous owner maintained excellent records on the car and there is no history of suspension work or replacement of parts since 2007 when tie rods were replaced. I realize that a 15 year old car will have issues, but I would very much appreciate suggestions of key areas to look at. Regards, |
Have you gone over the suspension to make sure nothing is loose? When was the last time the car had an alignment?
It sounds as if the car certainly needs an alignment. Where in Washington are you located? If you’re in the Seattle area, I have some good shops for you to to try.
Seems kind of obvious... but, have you checked your tire pressures and age of tires? If you have checked pressures, what are they?
I have an 03 S also and I think that there isn't any issue with your steering as they are very stiff and responsive. As for changes in road condition I think that it's pretty normal if it wants to follow the contours of the road, and when you hit a pothole it's kind of normal to be jumpy.
Thank you for all the responses. I will double check tire pressures, and get the solid look at the suspension to see if anything is loose or their is an alignment issue.
This could also by driver induced as my daily driver is a M4 and very much a different car. |
May not be related, but check the power steering fluid. It is a PITA to do, so lots of people neglect it.
AND don't use any garden variety ps fluid. Porsches use Pentosin CHF 11s. |
Definitely have the tires, suspension and steering fluid and linkages checked out. I’ve owned my 03 S since new and now have 76k miles on it. The steering has never felt heavy, even after adding an underdrive pulley. And it isn’t darty at all, my alignment is on factory settings, not aggressive for the track or anything unusual.
Alignment...
| All times are GMT -8. The time now is 12:19 AM. |
