-   -   RPM's and MAF at Idle (http://986forum.com/forums/boxster-general-discussions/72446-rpms-maf-idle.html)
Lew 06-08-2018 11:13 AM
This is a screen shot with the engine at operating temperature. I am not seeing a steady reading. When raising the RPM's with the pedal, the RPM's are not steady nor is the MAF readings.
Any ideas why this is happening.
http://986forum.com/forums/uploads02...1528481514.jpg
Lew 07-01-2018 10:24 AM
JEF in PA what do you think?
JFP in PA 07-01-2018 01:28 PM
If there are no codes involved, I would guess that the MAF may be dirty and needs cleaning, or may be on the way out itself. However, if you have codes, I would like to see them.
Lew 07-01-2018 01:39 PM
Have had only one P0139 on a quick scan with the Durametric and cleared it. It has not come back in a few weeks. I removed the MAF and cleaned it with the CRC cleaner a while back. New plugs at 30K and at present just 3k on them. I may have a vacuum leak somewhere. Going to look especially at the foam rubber around the Air Cleaner box. That's about it JFP.
JFP in PA 07-01-2018 02:34 PM
If the P0139 was real, you have an O2 sensor aging out on bank 1-3, which is one of the tools the MAF uses to try and control the mixture. If you also have a vacuum leak as well, that will also drive the MAF nuts.
I would use your Durametric to watch both O2 sensors on bank 1, to see if their voltages are inline. Could be the root of your issues.
Lew 07-01-2018 05:36 PM
Thanks for the advise JFP. I will monitor the voltages. I may remove the MAF and spray clean it again, and use a little dielectric grease on the connector. I didn't do that last time out. Sound OK using the dielectric on the connector?
JFP in PA 07-02-2018 02:50 AM
I would not put anything on the MAF connector. Low and partial voltage sensors can be upset by the slightest things. Clean the connector with a proper contact cleaner and leave it alone.
Lew 07-02-2018 04:33 AM
Thanks for that advise JFP. I didn't think about cleaning the connector when cleaning the MAF, but will do ASAP.
