Old 05-29-2018, 04:20 PM   #1
pidj's Avatar
Found in passenger footwell
I found this screw. Torx head and ~1/2 inch long ... can anyone identify it?
Thanks in advance!
2001 Boxster S, Guards Red
pidj is offline   Reply With Quote
Old 05-29-2018, 06:00 PM   #2
kirkandorules's Avatar
Lots of these used in our cars, but based on where you found it my guess would be either in the dash for the stereo, one of the pieces attaching to the roof frame, or the roof latch.
'99 986 Ocean Blue Metallic
'87 924S, winter beater
'17 VW Golf Sportwagen, for when I need extra seats
kirkandorules is offline   Reply With Quote
Old 05-29-2018, 06:13 PM   #3
There Is No Substitute.
rick3000's Avatar
Probably from the plastic caps on the end of the seat rails.
Old 05-29-2018, 07:15 PM   #4
Jager's Avatar
Is that one of the screws for the door panel? The foot well is a great place to put screws and other parts when you are taking something apart... Like the door panel.
Jäger
300K Mile Club
Old 05-29-2018, 08:31 PM   #5
Cunningr's Avatar
Looks like a door panel screw.
Old 05-30-2018, 09:31 PM   #6
Damn Yankee
TeamOxford's Avatar
Thanks in advance!
Hey! That's mine! I lost it when I was in...............Canada...............yeah, that's where I was.
I was in Canada and I lost that screw.........yeah, that's the ticket!
TO
Old 05-31-2018, 03:43 AM   #7
Artist, 986S tinkerer
NewArt's Avatar
TO
Hahaha!
Old 06-01-2018, 03:26 AM   #8
pidj's Avatar
TO
Lol!! I'll have a look at the vertical part near the jamb, RandallNeighbour
It's too small compared to the top latch screws etc. I did clean and reinstall my Lloyd's mats and they have a seat rail connector, but I can't even see where a screw would filt there; it's snap together ...
Old 06-01-2018, 04:06 AM   #9
Cunningr's Avatar
I am 98% sure its a door panel screw, probably from under the door handle release, or from under the convenience light on the door panel.
There are 3 but can't remember exactly legths, one under door release, one under the small .5" wide cover on the pull handle, and one under the light.
If you have door speakers could be from the speaker box also, they are the same as that one there are 4 that hold the speaker enclose to the door.
Old 05-31-2018, 04:01 AM   #10
That's a fat little stubby screw, right?
Look at the door at the latch area on the end of the door where it meets the vertical part of the jam on the car. Do those screws look similar?
Old 06-01-2018, 04:55 AM   #11
pidj's Avatar
Well, if it's a door panel screw, it's well concealed. I have rich shag carpeting on the bottom half of the door, around the speaker. I can't see where a screw would fit, much less where the existing screws are
Old 06-01-2018, 05:46 AM   #12
Cunningr's Avatar
Yeah they are concealed. One is under the plastic cover where the door handle is located, on the door panel pull handle there is a small plastic piece you remove to access another, and the other one you have to remove the actual door light like to change the bulb its located under there.
For the speaker boxes in the door, pretty much have to remove door panel, could be someone had the boxes out missed putting one back in. But as mentioned these cars have a lot of those holding things together.
Old 06-02-2018, 12:51 AM   #13
Bush screw?
