Old 05-25-2018, 05:17 PM   #1
Squeak when clutch pedal out
I noticed a weird sqeaky noise the last few days in my 2004 S.
It's there when the clutch pedal is out and it goes away when I push the clutch in or even apply a little pressure on the pedal.
I had my clutch replaced two summers ago, so I don't think it's a bearing or such.
I read some info that it could be a loose heat shield - does that sound fesible?
Other ideas to check?
soxfan1966 is offline   Reply With Quote
Old 05-25-2018, 05:48 PM   #2
BYprodriver's Avatar
Usually the throwout bearing.
Old 05-26-2018, 06:06 AM   #3
Yes, probably. Irritating but there's no great hurry to replace it.
2001 Boxster
2007 Toyota Highlander
Old 05-26-2018, 06:16 AM   #4
Would the bearing make more of a sqeal / grinding noise as opposed to a squeak?
Old 05-26-2018, 06:39 AM   #5
Here is a video I took of the noise
https://youtu.be/5DNtKoDww6Y
Old 05-26-2018, 04:53 PM   #6
My 03 S made the same noise a couple of years ago. My mechanic put it on the lift and had someone in the car working the clutch to see where the noise was coming from. He said they do that sometimes but it wasn’t a problem. I forget if he said it was the pressure plate or the throw out arm. I drove it some more and the noise went away. It hasn’t returned.
Old 05-26-2018, 07:45 PM   #7
Is it when you release the clutch, or does it squeak with the pedal out in general? If it squeaks when you release the clutch, particularly when warm, it’s either your spring, or the slave. Pretty common “issue” that’s really more of an annoyance than an issue.
Old 05-27-2018, 01:38 AM   #8
It happens when the clutch is fully released, not as I'm releasing it. The video is with the clutch released (pedal out) but not in gear. Makes same noise in gear too.
Old 06-09-2018, 05:23 AM   #9
Any update on this?
"YouTube Certified in Various Specialties"
Old 06-09-2018, 04:07 PM   #10
Originally Posted by BFeller View Post
Any update on this?
I talked briefly with the mechanic who did my clutch two years ago and he confirmed the throwout bearing was replaced.
He suggested taking the bolt holding the slave cylinder on and spraying some lubricant (white lithium grease) in the hole to try and lubricate things and see if that helps. I have not had a chance to do that yet, was going to give it a whirl tomorrow if I get the chance.
Old 06-10-2018, 02:55 PM   #11
I did not get the chance to do this today, may be another week or so until I get the chance.
Old 06-18-2018, 07:08 AM   #12
Finally had a chance to jack up the back of the car and give this a try. From what I read, this sounded pretty straight forward but I had a hard time finding where the slave cylinder even was. The info I read made it seem like it was easily accessible from underneath but once I found it I realized it was more toward the top of the transmission as opposed to the side. I did not feel confident I could do this on my back under the car (which was up on jack stands). So I stopped. Checking with mechanic who did clutch to see if he can do this when he has car on a lift.
Unfortunately, while I was under the car looking for the darn slave cylinder I noticed one of my spark plugs coils had a crack - it's at the bottom between the mounting screws but should get replaced. Need to see how many others insame boat (the other two on driver's side looked ok).
