05-21-2018, 12:32 PM
03/04 glove box retrofit to earlier years possible?
Hi all,
Can you make an 03/04 glovebox/dash fit into earlier years?
If so, what goes into this procedure and is it even worth the task that is required?
Any leads on this would be much appreciated.
Thanks,
Randy
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
05-21-2018, 12:45 PM
I recall a posting years ago asking the same question and the conclusion was it was an enormous task involving the entire dash support structure. Don't recall ever seeing someone do it and posting pictures or instructions.
05-21-2018, 01:05 PM
I thought I did too, but I can't seem to find the post anywhere.
My dash has the leather lifting slightly from the front where the rain sensor is, probably from sitting in the sun I'm guessing, so it would be a good opportunity to refresh it with a new dash from an 03, along with a glove box. Of course, only if it's possible...
05-21-2018, 01:13 PM
still plays with cars...
Can’t recall where I saw it, but there was a thread somewhere saying the entire 2003-04 dashboard is interchangeable with older models.
Six speed 2000 Boxster S
05-21-2018, 01:14 PM
Yes, you can! But you must swap dashboards with a 03/04. Thats it! So if you need a how to, just lookup how to remove the Dashboard in a 986/996, and install is reverse.
Actually about to do this to mine.
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
05-21-2018, 01:18 PM
Originally Posted by DarkStar
Yes, you can! Actually about to do this to mine.
the answer I was seeking! how did you come to this conclusion? did you see a thread somewhere that someone has already done this?
05-21-2018, 02:01 PM
There Is No Substitute.
I remember that thread. Conclusion was that it would require replacing the entire dash, but I think 1 or 2 people where crazy enough to do it. Here's the thread:
Glove Box in the 986
05-21-2018, 03:51 PM
Just wanted to mention to the guys doing the dash replacement...
While you have the dash out would probably be a great time to replace the foam on your heater box flow control doors...
05-22-2018, 01:22 PM
Another note ...
The later dash features completely different center plastic, i.e. hvac vent, switch mounts, radio mounts, etc. So, you need those parts, too.
FWIW the expensive cupholder (standard equipment) for the new dash doesn't take up an entire mounting space as does the earlier cupholder option.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
05-22-2018, 09:57 PM
Originally Posted by lkchris
Another note ...
Yeah, I already switched my center parts and vent to the 03/04 mainly because I fabbed in a 8.4" Tablet. But the Glove Box is what I want.
I've already removed the dashboard, it isn't difficult at all. Can be done by the average joe with the proper tools (google search Dash Removal 986) in a few hours, add an extra hour or two if you have help.
In case its not covered on wherever someone is reading, the center brace seen in my picture here is different, so you have to get this too. IF you don't, glove box wont install. If you don't install one, the dash will sag. Prob more with the added weight of whatever might be in the glove box.
And in case anyone asks why I put a Tablet in my car.... what better?
-Josh
05-23-2018, 02:32 AM
With the dash broken down that far if you haven't addressed the foam inside the Air Duct issue, would be a good time.
05-23-2018, 08:02 AM
It means changing the dashboard. Don't do it!!!!!! Been there, done that.
2001 Boxster, GT3 console delete, lower stress bar, RoW M030 suspension package, painted bumperettes.
05-23-2018, 09:19 AM
No Way? It's soo simple a 5yo child could do it so what's the problem?
05-23-2018, 09:47 AM
Originally Posted by Dubaday
Hi all,
Thanks,
Randy
anything is possible...
... with enough time and money
"Cool Prius!" - Nobody
05-23-2018, 10:38 AM
This however is possible via about $250 and 3hr of your Time.
-Josh
05-23-2018, 12:33 PM
05-23-2018, 08:41 PM
I don't necessarily need Ebay. There is a reliable Porsche Salvage yard in my city. I know for a fact right now they have an 04 Black/Silver Dash and the Matching Bose Door Panels.
I honestly don't get whats soo funny here? Removal of the Dashboard has been well documented by many on this site and other PCar Forums. It is not a hard nor long procedure.
-Josh
05-23-2018, 08:45 PM
Echo, echo, ....
My thoughts exactly!
05-24-2018, 08:48 AM
the center brace in this photo, is also in the 03/04 dash correct?
so for clarification purposes, if the parts car I'm sourcing this dash/glovebox from is still fully intact, I should be able to get all the parts I need from this car right?
Very much appreciated Darkstar, and BirdDog, lkchris, Cunningr for the info
12-26-2020, 08:27 PM
Dash retrofit
Hi All, I installed my dash with glove box.... now only to realize that the right duct work has to be altered. I read posts that said the center duct was different but didn't put 2 and 2 together and installed everything. I imagine the center and right are replaced. No way am i pulling everything out again. Is there a work around maybe using flexible duct work? Thanks v
