Old 05-20-2018, 10:11 AM   #1
key fob will not lock and unlock doors
bought 02 Boxster S last fall..
previous owner had dead battery for many months which affected settings in the computer.
only problem I cannot resolve is the key/security system
cannot get key to lock and unlock doors and trunks.
is there a quick fix?
it was working until previous owner turned off car to replace battery.
what might be the reset process?
Skip Mueller is offline   Reply With Quote
Old 05-20-2018, 10:36 PM   #2
BirdDog's Avatar
Skip
Are you sure that the battery in the remote (key fob) is not dead?
The car will stop listening for the remotes after about 5 days (the car turns this off to conserve power). After that you have to use the key (in the door) to get inside. Once you use the key to unlock the door you should be able to use the remote functions again.
As far as I know, the (car) battery going dead shouldn't mess up the computer's settings...
If there's a reset process I'm sure someone here will chime in...
My bet is that the battery in your remote (key fob) is dead.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 05-20-2018, 10:46 PM   #3
Insert key into door, turn to unlock position and press unlock key on fob.
I've read that this also works in the ignition. I believe the procedure for that is to turn key to "on" for 5-10 seconds (don't start car), turn off and remove key, then press unlock on fob within 5 seconds.
Information in books and online is conflicting...
Old 05-21-2018, 05:02 AM   #4
"50 Years of 550 Spyder"
10/10ths's Avatar
+3
What they said. Insert key into door lock, turn towards front of car to unlock. Then try remote buttons.
Enjoy.
Old 05-22-2018, 09:16 AM   #5
tried all suggested.
still will not react to key fob or button on dash
