05-11-2018, 07:07 PM
Rich
start up rattle
My 2000 boxster s has the cold start up rattle that many have reported. It only does it the first start of the day. I think it is a chain tensioner (all three are new) bleeding down or lifters bleeding down. Can an oil pressure release valve cause this noise? The noise is loud and i would really like to fix it. Verio cam tensioners and pads are also new.
05-11-2018, 07:24 PM
I had a similar noise after my car sat for a few days. In my case, replacing the filter housing (with it’s integrated valve) solved the problem. About $20 with filter from pelican last I checked.
98 Arena Red 986
05-12-2018, 07:29 AM
I would like to find a solution to this as well. I have replaced all three chain tensioners and the vario cam tensioners and pads (for other reasons). I have a new oil pressure release valve to install. If anything I think the startup rattle is worse after replacing the tensioners. I also installed a spin on oil filter adapter.
Dave in TX
2001S
05-12-2018, 07:57 AM
Interested to hear if this is something others have done. Filter housing as is in the plastic cartridge cover? From what I hear the lifter noise is normal due to the boxer engine design.
05-12-2018, 08:25 AM
"50 Years of 550 Spyder"
Cold start rattle is normal....
...it takes a few seconds for the tensioners to pump up with oil.
First Gen Miatas have a lifter tick on cold start up.
Nothing to worry about.
05-12-2018, 05:09 PM
still plays with cars...
Mine does the same thing too. I’m still running the original tensioners, but I’m using an LN spin on adapter. If it sits a couple of days it does the rattle thing.
It almost seems like the early 5 chain engines make the start up rattle more than the later engines.
I cringe when it rattles, so I turn the key until it just fires and the shut it down. I do this three times to prime the tensioners and it doesn’t rattle.
Six speed 2000 Boxster S
05-13-2018, 04:44 PM
Rich
https://www.youtube.com/watch?v=7mAuOw7dvYw
Is this the noise that others are hearing and recommend don't worry? Assuming these cars didn't do this new...we can fix them.
05-13-2018, 10:40 PM
That’s seems more harsh than simply letting it do its thing. Mine “rattles” for about 1-2 seconds if that. Lots of chains to be moving around all at once. Not a worry.
05-14-2018, 02:52 AM
I get some lifter ticking for about a minute when I crank up. I read that this is inherit issue for flat 6 motors, do to the orientation the oil leaks down. Same reason they have a little smoking the oil collects in the cylinder when it sits awhile.
05-14-2018, 02:54 AM
That is much harsher than what I get, that almost sounds like starter grinding.
05-14-2018, 11:37 PM
Yes, pretty much. Hard to tell in the video.
05-16-2018, 07:43 PM
How long does it go?
How long are people having this start up rattle? I was having it for about a second, and then it goes away.
01-09-2019, 07:53 AM
Mine is doing the same thing too. Does anyone know if this is something that needs to be fixed, or is it just a character of the engine?
01-13-2019, 06:23 AM
Check the two exhaust heat shields. They can rattle on start up.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
01-13-2019, 10:35 AM
1998 Boxster Silver/Red
I don't know if it was a "seat of my pants" experience... but when recently I replaced the pressure relief valve with the updated/upgraded part I swear that rattle was recognizably less audible, and has continued to be so. I drive the car about 3 times a month (for now).
Someone tell me I'm hearing things, or second my assumption.
Thank you.
1998 Porsche Boxster
01-14-2019, 08:37 AM
Yes it needs to be fixed, that's why Porsche reengineered the part in 2001 or 2002 with a integral spring to pre-tension the chain. there is a TSB that explains the issue & new part number. If you buy a new one from a dealer for a older Porsche you may get the original non-updated part.
