Old 04-13-2018, 06:14 PM   #1
M030 Strut/Shock Replacement
Hi all,
I put in an M030 from Suncoast about five years ago. I suspect the struts and shocks are losing their cookies. Anyone ever seen replacements for these? I recall they are shorter than stock, so replacing them with stock struts would be fairly fruitless.
TIA
Pat
Last edited by pek771; 04-13-2018 at 06:15 PM. Reason: my typing skills have eroded
pek771 is offline   Reply With Quote
Old 04-15-2018, 12:48 PM   #2
Apart from another set of M030 struts/shocks I have no idea but am curious to know.
__________________________
'58 356A coupe, just a driver
356Guy is offline   Reply With Quote
Old 04-16-2018, 04:46 AM   #3
Cunningr's Avatar
I have been researching replacements also, but completely confused. I have a European Spec 2000S I believe it has the M030 option, almost certain. So in the US this would be known as the ROW M030 upgrade? In other thread I saw KONI Sports or FSD recommended as replacements, which is best for that option? Well I will be following your thread to see where this goes.
Old 04-16-2018, 12:04 PM   #4
Ciao's Avatar
Originally Posted by pek771 View Post
Hi all,
TIA
Pat
Do you expect aftermarket products will outlast the M030 struts/shocks?
It seems 5 years is a short duration for the M030. I have Bilstein coilovers on my Audi that are 11 years old and seem to be doing well. So, I was considering replacing my Box's suspension with Bilstein coilover for the Box
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 04-16-2018, 03:16 PM   #5
edc
550 Anniversary
edc's Avatar
My M030 was 115k and 13 years old until swapped out for no other reason than i wanted it perfect and box fresh. It would have still kept going. Indeed the danker Dyno shows them all as perfectly useable. I also know how a new M030 car drives as I did that to my previous Boxster and of course you can tell the difference.
