IMS Bearing identification
I have the original IMS bearing that the PO removed while changing a leaky RMS. Is there a way to identify if it was a single, or double row bearing? Are there specific dimensions to look for? You can't tell much by looking at it.
Thanks! |
Does it have the seals still intact? If so, remove them and look. You don’t need it to be serviceable. You should be able to see one, or two rows of bearings I would think?
| All times are GMT -8. The time now is 10:14 PM. |
