-   -   Any tricks for attaching AOS accordion hose? (http://986forum.com/forums/boxster-general-discussions/71284-any-tricks-attaching-aos-accordion-hose.html)
Stiles13 03-07-2018 03:14 AM
I am replacing my AOS on my 2001 Boxter and struggling mightily. I have tried attaching the hose to the engine first and vice versa. I also have to replace the lower vent hose as it cracked during removal.
Burg Boxster 03-07-2018 06:59 AM
Typical internal dialogue installing an AOS includes "you know, having a third hand sure would be helpful right about now..."
Attaching to AOS first as I recall is preferred route - not to mention benefit of installing one clamp completely outside engine bay. The Porsche repair manual calls for, and of course dealers sell, an extremely overpriced lube for the job. A loving dealer, if they even permitted you to buy, would apply generously before charging to minimize pain inflicted :eek: A loooong time ago, I inquired and it was something ~ $30 for a tube size no larger than TSA friendly toothpaste... of which you only need a pea sized gob or two. Needless to say, I declined.
A schmear of motor oil just inside of tube opening is equally effective for encouraging it to slip on so you can attached hose clamp.
Good luck :)
