Old 02-16-2018, 07:12 AM   #1
Dubaday's Avatar
wheel fitment question
I have an opportunity to pick up some rather wide wheels, was wondering if y'all can chime in with your opinions if these will fit. Currently stock suspension.
Wheel specs;
Front - 18 x 9 offset 23
Tires - 225/40/ZR18
Rear - 18 x 11 offset 20
Tires - 285/30/ZR18
Very much appreciated guys,
Randy
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
Dubaday is offline   Reply With Quote
Old 02-16-2018, 07:42 AM   #2
The Radium King's Avatar
fronts maybe. rears no way. first pic in linked thread is of 275 tire (ie, 10 mm/0.5" narrow than yours) on 10" wheel (ie, 24mm/1" narrower than yours) with ET34 offset (ie, 24 mm/1" further inboard than yours). so, take that pic, stick the wheel out an additional 1", than make it 1/2" wider than that.
Old 02-16-2018, 10:41 AM   #3
Dubaday's Avatar
Thank you TRK, I suspected that it wouldn't fit as well but wanted some insight from others.
They look so good too....
https://seattle.craigslist.org/see/wto/6491106457.html
Old 02-16-2018, 11:01 AM   #4
well, they are 3-piece wheels, so you can swap/replace barrels to get the width/offset you want. vendor seems to know what he's talking about; ask him if possible to rebuild wheels for boxster fitment - you want *around* et40 front and rear (really depends on what tire you are carrying, but 40 is pretty safe) and max 10" on the back.
Old 02-23-2018, 10:10 AM   #5
17" Techart OZ Championship Formula wheels
