02-11-2018, 09:11 PM
gauge cluster wiring diagram
hi. looking for connector assignments, pinouts, wiring diagram, whatever you have, for a 2003/04 boxster (or 996) instrument cluster. hard to find!
02-12-2018, 10:51 AM
I just looked it up in the Sacred Tomes: Book 'Group 9 Circuit Diagrams Part 2', Chapter '03, Sheet 2:
Link for full size, print them, and tape together...
02-12-2018, 11:19 AM
thank you sir, much appreciated. also got some help on rennlist which has provided me w a great deal of good stuff if interested. cheers.
02-12-2018, 11:25 AM
and, this should be the final piece i need to complete a connector assignment conversion chart to put a 7.8 dme in a 7.2 dme car (along with swapping ABS pump/HVAC controller/instrument cluster/wheel speed sensors, conversion to 4-channel ABS and non-return fuel pump); i'll make available once complete and ground-truthed.
02-13-2018, 03:59 PM
It's all in the Bentley manual ...
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
02-13-2018, 08:38 PM
My Bentley only has wiring diagrams for 1998 DME 5.2.2 and 2001 DME 7.2, published in 2005. Is there one with the 2003-2004 7.8 diagrams? Probably minor differences, but differences.
04-15-2022, 03:14 AM
Hi, first thanks for the infos.
So, if i got it right
B2 = oil level
B5 = oil pressure sensor (not used)
A13 = oil pressure switch
Does anybody know which plug color is A and B on FL cars?
2003 FL cars do have a green, a blue and a grey plug.
On pre FL cars
PLUG 1 = Blue
PLUG 2 = White
PLUG 3 = Black
But how is that on FL cars?
04-15-2022, 07:36 AM
Here ya go Markus. If you can't read it let me know and I'll send you the full pdf.
04-15-2022, 11:56 AM
Hi Ike84.,
unfortunately that's much to small to be readable. I've sent you a PM.
Thanks, Markus
04-16-2022, 01:00 AM
Ike84 had sent me wiring diagrams. Unfortunately they are for the year 2000-2002 cars.
I need the diagrams for 2003-2004 cars. So the facelift models.
If somebody can provide me with some infos - especially for the 2003-2004 instrument cluster wiring - that would be great.
Thanks a lot!
04-16-2022, 05:04 AM
Originally Posted by Smallblock454
... If somebody can provide me with some infos - especially for the 2003-2004 instrument cluster wiring - that would be great.
Thanks a lot!
B2 = oil level
Correct.
I already posted the full diagram of the cluster wiring in post #2 of this thread *except* for the color of the connectors which was cropped out of the top of the picture. Here it comes. (Spoiler alert....)
...are you ready?
Plug A: Green / Grün
Plug B: Blue / Blau
Plug C: Gray / Grau
04-16-2022, 07:40 AM
My problem is that doesn't make sense, because on the PCB B2 and B3 on Plug B (Blue) are connected. B3 is the sun temp sensor. That only would make sense if the sensors get connected to the IC via a bus signal. But i think that is all analog.
04-16-2022, 09:57 AM
There have been a few mistakes in the manual. Both of those sensors also have a ground.
Oil level shows:
Ground B18 with a brown/orange wire.
Signal B2 with a green/blue wire.
Sun sensor shows:
Ground B19 with a brown/orange wire.
Signal B3 with a black/red wire.
Is that what you observe?
Are B18 and B19 closed to PCB Ground?
04-17-2022, 12:31 PM
I translated it to a - in my opion - better chart. Seems to be right this way.
