Old 01-16-2018, 08:59 AM   #1
Alarm module circuit diagram
My 2000 Boxster alarm module got WET and I am have several issues now. Does anyone have a circuit diagram for the module? Mine is a M535 996.618.260.07
I'd be happy to do a write up on the repair.
Thank you,
Chris
cspaulding is offline   Reply With Quote
Old 01-16-2018, 10:27 AM   #2
Loren might not like this but I posted some info on this thread that might help you.
https://www.renntech.org/forums/topic/48679-dme-alarm-module-key-swap/?tab=comments#comment-293090
Porsche-Eh is offline   Reply With Quote
Old 01-16-2018, 10:33 AM   #3
I should mention, if it only got wet you can likely fix it by removing, taking off the plastic case and submerging in isopropyl alcohol. Use electronic grade (90%). Rubbing alcohol is around 70% so still lots of water in it. Let dry and reinstall. This fixes most.
Old 01-16-2018, 12:25 PM   #4
Outstanding! Thank you!
