Old 01-15-2018, 06:14 AM   #1
Beginner
Jamesp's Avatar
A riddle, wrapped in a mystery, inside an enigma
No, it's not Russia.
It's the behavior of my horn after replacing my ignition switch with a new one.
With the key removed the horn works at all steering wheel positions.
Insert the key, but do not turn the key, the horn works at all steering wheel positions.
Turn the key to the run position, and the horn does not work at any steering wheel position (engine running or not).
Turn the key to the off position but do not remove it, the horn does not work.
Remove the key, and the horn works again.
Any thoughts?
2003 S manual
Old 01-15-2018, 07:22 AM   #2
Originally Posted by Steelepuls View Post
My car did the same thing with the horn, there is a ground on the steering wheel under the airbag that was broken, the sheathing was intact but the wire underneath was broken. Undo the battery, wait a while and remove the airbag. There is a female ground connector on the steering wheel, check if it is still intact. I reconnected the ground with a new flag connector. Works fine now.
There is a YouTube video if you do a search. I tried linking an older thread, looks like I just quoted myself instead. Sorry.
Steelepuls is offline   Reply With Quote
