Old 11-23-2017, 06:58 PM   #1
Pdwight's Avatar
Warm air.....well a little
I still have not gotten around to replacing my water pump, just working two jobs is a pain. MY car never runs hot, however this year when I increase the temperature on the control I have go all the way to the top to get really warm air out of the vents. My reservoir in the trunk is exactly where it should be on coolant level. My water pump is not noisy or leaking I am just wanting to do a preemptive PM on the car as I just hit 80K miles....Ideas ???
Thanks in advance
Dwight
Old 11-24-2017, 01:31 AM   #2
A preemptive strike on the waterpump won't hurt but I don't think that is your issue . I believe your issue is related to the breakdown of the foam insulation on the flapper doors in the heater box in the dash . You can get heat out of the system but generally have to set it to max temp but it will bleed down to luke warm . At least that what mine does .
rfuerst911sc is offline   Reply With Quote
Old 11-24-2017, 04:16 AM   #3
Read this...
Interior vent debris
I had the same issue, lukewarm heat even at Hi, did this repair yesterday and it produces hot air now! Also fixed center/ side vent control flap too, it was blowing air all the time. Added more air flow to defrost and floor when closed.
Old 11-24-2017, 01:01 PM   #4
+1. I'm in NW FL and notice that during the rare times I want to run my heat full blast, my air is so so (as in not so) warm. I know my foam is long gone as it finally stopped blowing out the vents a few years ago. The issue is on my list but just not important enough for me to get excited about it or move it up the list.
dghii is online now   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
