Old 11-12-2017, 09:46 PM   #1
Headlight: Noticed this a few days ago
My headlights work perfectly, Litronix 2001 Boxster S but, I noticed this
A few days ago. Should I be worried? Doesn't seem loose.
RobertKing is offline   Reply With Quote
Old 11-13-2017, 01:51 AM   #2
Hard to tell from the pic if the lense is cracked or if it's the protective clear coating that is peeling . Supposedly Porsche used very good quality lexan for the lense so I'm leaning towards it being the clear coat .
Old 11-13-2017, 03:51 AM   #3
oldskool73's Avatar
looks like either damage to the clear, or the remains of some kind of coating or film that used to be on them. If you run your finger over it does it feel raised or lowered at all?
oldskool73 is offline   Reply With Quote
Old 11-13-2017, 02:13 PM   #4
Need For Speed
KRAM36's Avatar
Sand, polish to a shine and apply headlight UV protection clear coat it. Will look good as new.
2003 Boxster S
Old 11-13-2017, 05:25 PM   #5
Scratched around it with a fingernail, looks like very thin plastic coating of some kind. Is there a protective film on these headlights normally?
Old 11-13-2017, 05:38 PM   #6
Which would be the better choice? The spray on stuff or the film?
Old 11-13-2017, 05:47 PM   #7
That's definitely clear coat peel.
Old 11-13-2017, 06:43 PM   #8
Seems to be the consensus... Any advice on fixing this?
Old 11-13-2017, 06:45 PM   #9
Need For Speed
KRAM36's Avatar
Spray on for sure. You can make your headlights look like new.
What I use to protect my headlights is the Dupli-Color Headlight Restoration Kit.
https://www.duplicolor.com/product/headlight-restoration-kit
You will need to get sand paper and polish. You will use a more coarse grit to get the current damage removed and move to less coarse grit in increments ending with a 3000 grit.
Then use some Mother's Mag & Aluminum Polish to polish the headlights to a perfect clarity. You can do this by hand or get a polishing pad that attaches to a drill and it will shine up quick and crystal clear.
Mothers® Mag & Aluminum Polish
Then clean the headlights off with a IPA solution to remove any product or contaminants to have a clean surface for the UV protection to stick to.
The Dupli-Color spray protection is very forgiving. You would have to try really hard to screw it up. Here is a video about the kit. You can see how easy the spray protection is to put on. Pull your lights out, much easier that way.
2003 Boxster S
Old 11-13-2017, 07:15 PM   #10
Looks like my weekend is going to be a busy one then.
Old 11-13-2017, 08:11 PM   #11
Need For Speed
KRAM36's Avatar
It's not really hard. Leave the lights in for sanding and polishing leverage, but tape off so you don't hit the rubber seal around the headlights or the paint. Then pull the headlights out and spray them. If the rubber seal around the headlights are in good condition, remove them before you spray the headlights and back on when you're done. You will have a big grin on your face when done and a great feeling of satisfaction of the job you did.
You should be able to get everything at like O'Reilly Auto Parts. This is the Polishing Pad I use.
https://www.oreillyauto.com/detail/masterpro-refinishing-4361/tools---equipment-16488/body-repair-16510/polishers--buffers--pads---bonnets-17962/polishing-foam-pad/67960/4511072?q=polishing+pad
Also wet sand the headlights and do not use a circular motion. Just go up and down the headlight from top to bottom in one direction.
https://www.oreillyauto.com/detail/dupli-color-3391/chemicals---fluids-16461/paint---body-repair-16614/headlight-lens-repair-19109/headlight-restoration-kit/hlr100/4268130?q=Dupli-Color+HLR100
Mother's Mag & Aluminum Polish.
https://www.oreillyauto.com/detail/mothers-4408/chemicals---fluids-16461/cleaners-16866/waxes---washes-16651/metal--chrome---wheel-cleaner---polish-17738/mag-aluminum-polish/05100/4526703
Get some wet sanding paper, start at 800, then 1500, then 2000 and finish sanding with 3000 grit. Pick up some microfiber towels also.
2003 Boxster S
Old 11-14-2017, 03:26 AM   #12
Multi-Boxer Driver
Deserion's Avatar
I'm curious on using the Mag/Alu polish for the plastic. When I did a few sets I used plastic polish.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 11-14-2017, 05:07 AM   #13
Need For Speed
KRAM36's Avatar
Mother's Mag & Aluminum polish will bring the headlights to a crystal clear state and do it quickly. It's perfect for the job, give it a try next time and you will see.
2003 Boxster S
