Wheel Bolt Size When Moving to 18"
When installing a 18" wheel from a 17" wheel do you need to get longer wheel Bolts?
Front; Offset: 50mm Rear: Offset: 47mm for 10J 52 mm for 9J |
No. You only need longer bolts if you use spacers to space the wheels out further than their normal offset.
Assuming they are all OEM wheels too. Not sure if any aftermarket wheels require different length lug bolts.
| All times are GMT -8. The time now is 02:25 PM. |
