Old 10-20-2017, 10:30 AM   #1
Headlights for idiots
Hi guys
Took ownership of my first porsche this week and had my first night drive only to discover driver side main beam light was gone. (Side and full beam fine)
Ive had a quick brush up on removal and got the bulb out (refreshingly easy) but got a simple question I need an answer to...
Are the bulbs specific to porsche or can they be replaced at any motorshop?
I live in Cyprus so sometimes overcoming language difficulties (I don't speak greek) can be a problem.
There is a porsche dealership out here but a good drive away so i thought I'd ask here first.
Sorry for the simplistic question. As said, first Porsche and first real "my" car as ive always had company vehicles where lazily if somethings broke, the company fix it!
Sent from my SM-G920F using Tapatalk
mikeyg is offline   Reply With Quote
Old 10-20-2017, 11:16 AM   #2
edc
550 Anniversary
edc's Avatar
It's just a standard fitment bulb any motor factors will stock.
Old 10-21-2017, 04:30 PM   #3
Yes, standard H7 bulb. When fitting, take care that the bulb is seated correctly and do check the headlights beam pattern on a wall to confirm. It should have an easily discernible cut-off.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
Old 10-21-2017, 05:36 PM   #4
Old 10-21-2017, 06:32 PM   #5
They are H7 bulbs. H4 bulbs will not work/fit.
Thanks! I’ve amended the original post so there’s no chance of someone being led astray by my brain fade
Old 10-22-2017, 06:15 PM   #6
if you are not up for quartz H7 go online to eBay and get a set of LED H7s......they are terrific and last a long long time
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
Old 10-22-2017, 11:09 PM   #7
Replaced.
Fun and games now tho.
Without the ignition key turned it won't light up when switched on (other passenger side one comes on)
Lights up fine when ignition on or engine started so not too concerning but a bit weird.
Side light doesn't come on now at all either so not sure if that has failed after taking out the unit. Will play more today!
