Old 10-09-2017, 01:37 AM   #1
Wow. Replacing spark plugs and all spark plug tubes on the right covered in oil
Not only that, but the coilpacks in 2 out of 3 cylinders have split rubber and there's some oil on the spark plugs in those. I had a P1124 and P1126 CEL, but don't think they relate to this and am betting more on AOS or dirty MAF for those. I did sense a slight hesitation at 4k, so perhaps this is where that's coming from.
I'll definitely be replacing the spark plug tubes. Can I replace just the two coilpacks that have split rubber, or is it necessary to replace all 6 at the same time? Would prefer to save money where possible as this last week has been expensive.
chromecarz00 is offline   Reply With Quote
Old 10-09-2017, 03:36 AM   #2
Project Addicted
jcslocum's Avatar
Just replace what is deemed bad. Inspect the coils closely for cracks.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 10-09-2017, 09:03 AM   #3
The soft, silicone rubber "boot" part of the coil pack is available separately, and should cost a lot less than replacing the entire coil. The replacement number is 996-602-103-01.
2001 Boxster
Old 10-09-2017, 10:14 AM   #4
Hey, that's good to hear. I'll get that separately, thank you
Old 10-10-2017, 06:06 PM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
FYI, I just dealt with both of those codes and it ended up being a vacuum tube under the intake that had come loose.
