Old 10-08-2017, 08:36 PM   #1
Ben
Trouble removing oil pan on 1997 2.5
My 1997 Boxster oil pan doesn't have the "boss" that would enable you to pry it off. See photo. My oil pan doesn't have the protruding piece that is circled. It doesn't appear to have ever had it-the finish is factory smooth. Any tips on getting this pan loose?
sactostrat is offline   Reply With Quote
Old 10-08-2017, 09:45 PM   #2
A rubber mallet or other soft material mallet should be more than sufficient to break it loose.
RobertKing is offline   Reply With Quote
Old 10-09-2017, 04:59 AM   #3
agreed a rubber mallet should get it started. You could also try carefully breaking the silicone seal with a putty knife or similar. Once you get it loose in one spot it comes off very easily.
There are other places to very gently pry if you look around.
Use caution.
Old 10-09-2017, 09:47 AM   #4
redciv1's Avatar
I just replaced my oil pan in June and I tried the rubber mallet first but nothing. As Quadcammer said I used a utility knife and a flat edged screwdriver, then and sharp, to brake the seal and slowly pry the two pieces apart. Be carefully of scratching the 2 surfaces. I may have even wrapped the head of the screwdriver with a rag as well.
redciv1 is offline   Reply With Quote
Old 10-09-2017, 02:16 PM   #5
Ben
Success. Thanks for your suggestions. I used a thin plastic spatula and a rubber mallet. The spatula broke, but the oil pan is off.
